1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: dbst problem when built against 3.13.1(actually problem with capfast symbols)
To: [email protected]
Date: Tue, 02 Feb 1999 11:28:39 -0800 (PST)
Hi Rozelle -
Thanks for your response on the new dbst behavior.
>I haven't changed dbst, I simply report out fields that are different
>from the default.  It is possible that dbStaticLib has changed.
>I believe the problem is that global link fields are  really strings,
>so the default is the empty string rather
>than 0.00000000000e+00 (as it appears in all the capfast symbols).
Yes, dbIsDefaultValue has changed (and there is a comment in the release
notes for the changes between beta11 and beta12) so that fields with
zero's are now dumped instead of ignored.  I assume the reason for this
change is to allow people to override a field with a non-zero default value
with zero.
>I had a problem with DOL fields inadvertantly initializing analog out
>records to 0.0.
>I went through  and did a global edit on .sym files
>that have DOL fields  and changed def(DOL) from
>def(DOL):0.000000000000000e+00
>to
>def(DOL):
>This fixed our problem with analog outs.
>However, I think this should probably be done for all the other LINK fields.
>INP, FLNK, INPA, INPB   etc.
But not just LINK fields but all non-menu fields like PHAS, EVNT, etc.
So I'll need to go through ALL my capfast symbols and edit many fields.
I wish I was using gdct as my database tool...
Thanks again,
Stephanie
Prev: EPICS Meeting '98: Presentations Ralph Lange
Next: KEKB status:Thanks to all of you. Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  <19992000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: dbst problem when built against 3.13.1(actually problem with capfast symbols) Rozelle Wright
Next: Notes on building extensions against R3.13.1 base saa
