Subject: |
Re: dbst problem when built against 3.13.1(actually problem with capfast symbols) |
[email protected] (Rozelle Wright) |
To: |
[email protected] |
Date: |
Mon, 1 Feb 1999 13:13:57 -0700 |
> From [email protected] Mon Feb 1 12:23 MST 1999
> Date: Mon, 01 Feb 1999 11:20:34 -0800 (PST)
> Subject: dbst problem when built against 3.13.1
> To: [email protected]
> X-Vms-To: IN%"[email protected]"
> X-Vms-Cc: SAA
> Mime-Version: 1.0
> Content-Transfer-Encoding: 7BIT
> X-Lines: 23
> Hello -
> Recently, I rebuilt a subset of extensions against R3.13.1
> (with a little more effort than anticipated - I thought it would
> be a matter of changing a few CONFIG files and rebuilding - Not!).
> So far, the extensions that we use are all working as before except
> for dbst, the tool that checks .db files and strips out unnecessary
> lines. I believe dbst is used mostly by people who generate .db
> files from CAPFAST schematics via e2db.
> The R3.13.1 dbst does not strip out fields that are initialized to
> zero. As a result, the .db files it generates are significantly
> bigger and IOCs take longer to reboot. Also, it can affect bumpless
> reboot if you restore your subroutine/calc inputs before
> InitHookafterInitDatabase (the zeros will override what you restore
> for these).
> Has anybody seen this problem and fixed it? My first guess is that
> there is a change to some dbStatic routine that is called by dbst.
> Thank you,
> Stephanie Allison
Hi Stephanie,
I haven't changed dbst, I simply report out fields that are different
from the default. It is
possible that dbStaticLib has changed.
I believe the problem is that global link fields are really strings,
so the default is the empty string rather
than 0.00000000000e+00 (as it appears in all the capfast symbols).
I had a problem with DOL fields inadvertantly initializing analog out
records to 0.0.
I went through and did a global edit on .sym files
that have DOL fields and changed def(DOL) from
def(DOL):0.000000000000000e+00
to
def(DOL):
This fixed our problem with analog outs.
However, I think this should probably be done for all the other LINK fields.
INP, FLNK, INPA, INPB etc.
Rozelle
dbst problem when built against 3.13.1 saa
Notes on building extensions against R3.13.1 base saa
<1999>
Re: dbst problem when built against 3.13.1(actually problem with capfast symbols) saa
<1999>
