1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: R3.13.1
To: Ralph Lange <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 17 Dec 1998 09:53:28 -0500 (EST)
On Thu, 17 Dec 1998, Ralph Lange wrote:
> > Creating directory exampleApp
> > Copying file /usr/util/epics/base/templates/makeBaseApp/top/exampleApp/Makefile -> exampleApp/Makefile
> > Not a directory Copying /usr/util/epics/base/templates/makeBaseApp/top/exampleApp/Makefile/.wind -> exampleApp/Makefile/.wind at /usr/util/epics/base/bin/sun4/makeBaseApp.pl line 249.
> This is even stranger than I thought.
> Which version of perl are you using? makeBaseApp needs perl 5. If you're
> calling makeBaseApp.pl directly from the command line, the first perl in
> your PATH will be used.
perl -V gives:
Summary of my perl5 (5.0 patchlevel 4 subversion 3) configuration:
  Platform:
    osname=sunos, osvers=4.1.4, archname=sun4-sunos
    uname='sunos ler014.ph 4.1.4 1 sun4m '
    hint=recommended, useposix=true, d_sigaction=define
    bincompat3=n useperlio=undef d_sfio=undef
  Compiler:
    cc='gcc', optimize='-O', gccversion=2.7.2.2
    cppflags='-I/usr/local/include'
    ccflags ='-I/usr/local/include'
    stdchar='unsigned char', d_stdstdio=define, usevfork=true
    voidflags=15, castflags=0, d_casti32=define, d_castneg=define
    intsize=4, alignbytes=8, usemymalloc=y, randbits=31
  Linker and Libraries:
    ld='ld', ldflags =' -L/usr/local/lib'
    libpth=/usr/local/lib /lib /usr/lib /usr/ucblib
    libs=-lnsl -ldbm -ldl -lm -lc -lposix
    libc=/lib/libc.so.1.9.2, so=so
    useshrplib=false, libperl=libperl.a
  Dynamic Linking:
    dlsrc=dl_dlopen.xs, dlext=so, d_dlsymun=undef, ccdlflags=' '
    cccdlflags='-fpic', lddlflags='-assert nodefinitions -L/usr/local/lib'
Characteristics of this binary (from libperl):
  Built under sunos
  Compiled at Oct 23 1997 09:53:25
  @INC:
    /usr/local/lib/perl5/sun4-sunos/5.00403
    /usr/local/lib/perl5/site_perl/sun4-sunos
> Is there a file called .wind somewhere under your EPICS base tree? Could it
> be that some weird mode bits of a file called .wind cause perl's find to go
> beserk?
I get no result from the command: "find . -name .wind -print" executed
in directory above base.
> Anyone else any idea?
John Sinclair
[email protected]
Oak Ridge National Lab
423-576-6362   423-574-1268 (fax)
Re: R3.13.1 Ralph Lange
Prev: Re: R3.13.1 Ralph Lange
Next: Re: R3.13.1 Ralph Lange
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
