1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Monitors on a stringin record
To: Ralph Lange <[email protected]>
Cc: Mark Rivers <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 11 Dec 1998 09:02:59 -0600
Ralph Lange wrote:
> > I have a naive question here.  I was under the impression that even if a
> > record requested that monitors be posted on a field which had not changed,
> > that channel access would not actually post the monitors if the values were
> > the same.  Is this true?
> Generally yes.
> When a CA client opens a monitor connection, it immediately gets the current
> value in the response and it is added to a list in the record.
> During record processing the record checks for its value to have changed and
> (if it has changed) sends out "value change events" to all the clients in
> the list.
> Ralph Lange
One extra comment.
For numeric records (ai, ao, longin, etc) fields ADEL and MDEL are provided.
These are alarm and monitor "deadbands". Values must change by specified amounts
before monitors are issued. If these are set to a negative value then monitors
are posted everytime the record is processed.
Marty Kraimer
Re: Monitors Brian McAllister
Re: Monitors on a stringin record Ralph Lange
Prev: Re: Monitors on a stringin record Ralph Lange
Next: constant links with strings Peregrine McGehee
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Monitors Brian McAllister
