1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Monitors on a stringin record
To: [email protected] (Mark Rivers)
Cc: [email protected] (EPICS Tech-Talk)
Date: Fri, 11 Dec 1998 15:46:03 +0100 (MET)
> I have a naive question here.  I was under the impression that even if a
> record requested that monitors be posted on a field which had not changed,
> that channel access would not actually post the monitors if the values were
> the same.  Is this true?
Generally yes.
When a CA client opens a monitor connection, it immediately gets the current
value in the response and it is added to a list in the record.
During record processing the record checks for its value to have changed and
(if it has changed) sends out "value change events" to all the clients in
the list.
Ralph Lange
Re: Monitors on a stringin record Marty Kraimer
Re: Monitors on a stringin record Mark Rivers
Prev: Re: Monitors on a stringin record Mark Rivers
Next: Re: Monitors on a stringin record Marty Kraimer
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
