1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Epics build system does not support cross compilers for host builds?
To: "Janet B. Anderson" <[email protected]>
Cc: [email protected]
Date: Tue, 24 Nov 1998 17:02:44 -0600
"Janet B. Anderson" wrote:
> > Am I correct in thinking that the Epics build system does not support
> The epics build system allows for only a single HOST_ARCH per build. If you
> have the base/config files settings correct, you should be able build multiple
> hosts by resetting the HOST_ARCH definition before each build. However, this
> has never been tried before so I am not certain it will work.
> Janet
The problem is that the make files don't make a distinction between targets that
should be built with the native host compiler (i.e. aitGen, flex & antelope)
which are executed during the build process and targets that should be built with
the cross compiler (i.e. libca.a, ca_test & excas) which are the final outputs of
the build...
It's no big deal, I can continue building on different hosts - it's just that the
m68k host is MUCH slower than the others!!!
Prev: MPF Release 1.0 (Hideos Replacement) Marty Kraimer
Next: Latch Record ? Paul Sichta
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Epics build system does not support cross compilers for host builds? Guy Jennings
Next: MPF Release 1.0 (Hideos Replacement) Marty Kraimer
