1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: possible channel access server problem
To: "'[email protected]'" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Fri, 13 Nov 1998 18:05:32 -0700
Kristi,
A problem was recently discovered at APS where certain 3.13 beta versions
of the CA client library were not closing the connection to an IOC when
the last channel on that connection was deleted. Since certain programs
like dm and MEDM delete a screen's channels when that screen exists, but do not
terminate the process, then the connection to the IOC will remain open
until the process exits. This in some situations has resulted in unreasonable
resource consumption in the IOC, but not permanent leaks because all
resources involved are reclaimed when dm or MEDM exit. We have fixed
this problem, and will hopefully make a release of the fixed version soon.
This problem exists only in beta version of R3.13.
I don't know why this one connection has so many unprocessed and
undelivered response bytes given that there is adequate CPU. There
may be mbuf starvation in your IP kernel. To investigate if this is the
case in the future type "mbufShow" at your IOCs console prompt.
Jeff
On Friday, November 13, 1998 4:27 PM, [email protected] [SMTP:[email protected]] wrote:
> Hi Jeff,
>  I was hoping you might be able to help
> with a possible channel access server
> problem.
> I am running EPICS R3.13.0.beta11 on a VME
> with an MV167. This ioc has a number of other
> ioc's monitoring channels, and in addition,
> a large number of dm and medm displays are
> usually connected.
> The problem that occurred was when a new
> display was brought up, all channels were white.
> At this time 42% of memory on the ioc
> was being used, the cpu usage was
> fine, and all other display were unaffected.
> I ran casr on the ioc and it showed the new
> client had indeed connected to the 21 channels on
> the display, but the unprocessed and
> undelivered response bytes were large and
> did not decrease. At this time there were
> also a few connections to 0 channels as well.
> After exiting the dm display, casr indicated
> that the connection was NOT dropped.
> Next, I brought up a display with
> approx 5 channels (medm) and all was well.
> Casr indicated that the connection was
> made and data was being shipped to the client
> (undelivered response bytes=0). And after exiting the
> display casr indicated that the connection
> was gone.
> Some additional side notes:
>   1. The ioc had not been rebooted in 5 days
>   2. We were able to monitor channels
>      successfully from cau and probe.
>   3. Of course rebooting solves the problem,
>       but I don't know for how long.
> We also have a number of connections to 0
> channels, which never go away. I don't know
> if this is a separate problem or realated.
> Below are some statisticts that I collected.
> I would appreciated any suggestions
> you might have that would help to
> narrow down this problem.
> MCC> show time
>   10-NOV-1998 10:48:38
> MCC> rlogin bic06pep00
> VxWorks login: BaBar
> Password:
> bic06pep00 ->
> casr(2)
> Channel Access Server V4.8
> Client Name="vxworks", Client Host="lfb04her00", V4.7, Channel Count=1
> 	TId=0XC1EDE0, Protocol=TCP, Socket FD=33
> 	Secs since last send 334661.09, Secs since last receive 334661.09
> 	Unprocessed request bytes=0, Undelivered response bytes=0
> 	Remote Address 172.19.55.55 Remote Port 1308 State=up
>         32986 bytes allocated
>        HB60:DCCT:SUMY(0rw)
> Client Name="vxworks", Client Host="lfb04ler00", V4.7, Channel Count=1
> 	TId=0XC1AFA0, Protocol=TCP, Socket FD=34
> 	Secs since last send 323066.84, Secs since last receive 323066.84
> 	Remote Address 172.19.55.50 Remote Port 3202 State=up
>         HB60:DCCT:SUMY(0rw)
> Client Name="epicscp", Client Host="opi00gtw00", V4.8, Channel Count=33
> 	TId=0XBB3CF0, Protocol=TCP, Socket FD=37
> 	Secs since last send   0.08, Secs since last receive   3.35
> 	Remote Address 172.19.55.48 Remote Port 57504 State=up
> 	37798 bytes allocated
> 	LB60:DCCT:MODULO(1rw)	HB60:DCCT:RAWTIME(1rw)	HB60:DCCT:DIDT(1rw)
> 	LB60:DCCT:DIDT(1rw)	LB60:DCCT:RAWTIME(1rw)	LB60:DECAY:CALCINV(1rw)
> 	HB60:DECAY:CALCINV(1rw)	LB60:DCCT:LIFETIME(1rw)	LB60:DCCT:LIFETIME(1rw)
> 	LB60:DCCT:LIFETIME(1rw)	LB60:DCCT:SUMY(1rw)	LB60:DCCT:LIFETIME(1rw)
> 	HB60:DCCT:LIFETIME(1rw)	HB60:DCCT:SUMY(1rw)	LB60:BNCHCURR:BXBTRIGR(1rw)
> 	LB60:DCCT:FHIST(1rw)	LB60:DCCT:20MIN(1rw)	LB60:DCCT:CHIST(1rw)
> 	LB60:DCCT:20MIN(1rw)	LB60:DCCT:LHIST(1rw)	LB60:DCCT:20MIN(1rw)
> 	HB60:BNCHCURR:BXBTRIGR(1rw)	HB60:DCCT:FHIST(1rw)	HB60:DCCT:20MIN(1rw)
> 	HB60:DCCT:CHIST(1rw)	HB60:DCCT:20MIN(1rw)	HB60:DCCT:LHIST(1rw)
> 	HB60:DCCT:20MIN(1rw)	HB60:BNCHCURR:BXBTRIGR(1rw)	HB60:DCCT:MODULO(1rw)
> Client Name="vxworks", Client Host="rfs12her03", V4.8, Channel Count=1
> 	TId=0XBAF9F0, Protocol=TCP, Socket FD=38
> 	Secs since last send 420576.78, Secs since last receive 420576.81
> 	Remote Address 172.19.55.61 Remote Port 1040 State=up
> 	33062 bytes allocated
> 	HB60:RF:BEAMON(1rw)
> Client Name="vxworks", Client Host="rfs12her01", V4.8, Channel Count=1
> 	TId=0XBABADC, Protocol=TCP, Socket FD=39
> 	Remote Address 172.19.55.60 Remote Port 1040 State=up
> 	HB60:RF:BEAMON(1rw)
> Client Name="vxworks", Client Host="rfs04ler05", V4.8, Channel Count=1
> 	TId=0XBA7B4C, Protocol=TCP, Socket FD=40
> 	Secs since last send 2971.72, Secs since last receive 420576.81
> 	Remote Address 172.19.55.69 Remote Port 1067 State=up
> 	LB60:RF:BEAMON(1rw)
> Client Name="vxworks", Client Host="rfs04ler04", V4.8, Channel Count=1
> 	TId=0XB91A68, Protocol=TCP, Socket FD=44
> 	Secs since last send 2971.73, Secs since last receive 420576.81
> 	Remote Address 172.19.55.68 Remote Port
> 1067 State=up
> 	LB60:RF:BEAMON(1rw)
> 	TId=0XB4C3C8, Protocol=TCP, Socket FD=45
> 	Secs since last send   0.12, Secs since last receive   7.22
> 	Remote Address 172.19.55.48 Remote Port 57505 State=up
> 	LB60:DCCT:LIFETIME(1rw)	HB60:DECAY:CALCINV(1rw)	LB60:DECAY:CALCINV(1rw)
> 	LB60:DCCT:RAWTIME(1rw)	LB60:DCCT:DIDT(1rw)	HB60:DCCT:DIDT(1rw)
> 	HB60:DCCT:RAWTIME(1rw)	LB60:DCCT:MODULO(1rw)	HB60:DCCT:MODULO(1rw)
> 	HB60:BNCHCURR:BXBTRIGR(1rw)	HB60:DCCT:20MIN(1rw)	HB60:DCCT:LHIST(1rw)
> 	HB60:DCCT:20MIN(1rw)	HB60:DCCT:CHIST(1rw)	HB60:DCCT:20MIN(1rw)
> 	HB60:DCCT:FHIST(1rw)	HB60:BNCHCURR:BXBTRIGR(1rw)	LB60:DCCT:20MIN(1rw)
> 	LB60:DCCT:LHIST(1rw)	LB60:DCCT:20MIN(1rw)	LB60:DCCT:CHIST(1rw)
> 	LB60:DCCT:20MIN(1rw)	LB60:DCCT:FHIST(1rw)	LB60:BNCHCURR:BXBTRIGR(1rw)
> 	HB60:DCCT:SUMY(1rw)	HB60:DCCT:LIFETIME(1rw)	LB60:DCCT:LIFETIME(1rw)
> 	LB60:DCCT:SUMY(1rw)	LB60:DCCT:LIFETIME(1rw)	LB60:DCCT:LIFETIME(1rw)
> Client Name="SLCSHR", Client Host="MCC.SLAC.Stanford.EDU", V4.8, Channel Count=92
> 	TId=0XABAD50, Protocol=TCP, Socket FD=50
> 	Secs since last send  56.47, Secs since last receive  56.47
> 	Remote Address 172.19.55.11 Remote Port 2867 State=up
> 	39538 bytes allocated
> 	HB60:BXBCM:REMOTE(0rw)	HB60:BXBCM:ATTENC1(0rw)	HB60:DCCT:LIFETIME(0rw)
> 	LB60:BNCHCURR:RATIO:RBCK(0rw)	LB60:BXBCM:ATTENC8(0rw)	LB60:BXBCM:PHASESA(0rw)
> 	LB60:DCCT:HALFLIFE(0rw)	HB60:BXBCM:RUNC(0rw)	HB60:BXBCM:ATTENM40(0rw)
> 	HB60:DCCT:SUMY(0rw)	LB60:BXBCM:ATTENC4(0rw)	HB60:STATE:ACT(0rw)
> 	LB60:BXBCM:PHASEMA(0rw)	LB60:DCCT:LIFETIME(0rw)	HB60:INJECT:SPACE(0rw)
> 	HB60:BXBCM:ATTENM20(0rw)	LB60:BXBCM:ATTENC2(0rw)	HB60:DCCT:SUMY(0rw)
> 	HB60:FILL:GOAL:STATUS(0rw)	LB60:BXBCM:REMOTE(0rw)	LB60:DCCT:SUMY(0rw)
> 	HB60:INJECT:REQ:NOP(0rw)	HB60:BXBCM:ATTENM10(0rw)	HB60:DCCT:RAW(0rw)
> 	LB60:BXBCM:ATTENC1(0rw)	HB60:FILL:GOAL:NORM(0rw)	LB60:BXBCM:RUNC(0rw)
> 	LB60:DCCT:SUMY(0rw)	HB60:INJECT:REQ:CHARGE(0rw)	HB60:BXBCM:ATTENM8(0rw)
> 	LB60:BXBCM:ATTENM40(0rw)	HB60:DCCT:DIDT(0rw)	HB60:BXBCM:ATTENC40(0rw)
> 	LB60:INJECT:SPACE(0rw)	LB60:DCCT:RAW(0rw)	LB60:STATE:ACT(0rw)
> 	HB60:BXBCM:ATTENM4(0rw)	LB60:BXBCM:ATTENM20(0rw)	HB60:BNCHCURR:SUMY(0rw)
> 	HB60:BXBCM:ATTENC20(0rw)	LB60:INJECT:REQ:NOP(0rw)	LB60:DCCT:DIDT(0rw)
> 	LB60:FILL:GOAL:STATUS(0rw)	LB60:BXBCM:ATTENM10(0rw)	HB60:BXBCM:ATTENM2(0rw)
> 	HB60:BXBCM:ATTENC10(0rw)	HB60:BNCHCURR:GOOD:SUMY(0rw)	LB60:INJECT:REQ:CHARGE(0rw)
> 	HB60:INJECT:SUMY(0rw)	LB60:BNCHCURR:SUMY(0rw)	LB60:FILL:GOAL:NORM(0rw)
> 	LB60:BXBCM:ATTENM8(0rw)	HB60:BXBCM:ATTENM1(0rw)	HB60:BXBCM:ATTENC8(0rw)
> 	HB60:BNCHCURR:RAW(0rw)	HB60:DECAY:SUMY(0rw)	LB60:BNCHCURR:GOOD:SUMY(0rw)
> 	LB60:BXBCM:ATTENC40(0rw)	LB60:INJECT:SUMY(0rw)	LB60:BXBCM:ATTENM4(0rw)
> 	LB60:INJECT:CAL:02(0rw)	HB60:INJECT:CAL:01(0rw)	LB60:INJECT:CAL:03(0rw)
> 	HB60:INJECT:CAL:02(0rw)	LB60:INJECT:CAL:04(0rw)	HB60:INJECT:CAL:03(0rw)
> 	LB60:INJECT:01CRAW(0rw)	HB60:INJECT:CAL:04(0rw)	LB60:INJECT:02CRAW(0rw)
> 	HB60:INJECT:01CRAW(0rw)	LB60:INJECT:03CRAW(0rw)	HB60:INJECT:02CRAW(0rw)
> 	LB60:INJECT:04CRAW(0rw)	HB60:INJECT:03CRAW(0rw)	HB60:INJECT:04CRAW(0rw)
> 	LB60:INJECT:CAL:01(0rw)	HB60:BXBCM:PHASESA(0rw)	HB60:BXBCM:ATTENC4(0rw)
> 	HB60:BNCHCURR:RATIO(0rw)	HB60:DCCT:INTCURR(0rw)	LB60:BNCHCURR:RAW(0rw)
> 	LB60:BXBCM:ATTENC20(0rw)	LB60:DECAY:SUMY(0rw)	LB60:BXBCM:ATTENM2(0rw)
> 	HB60:BXBCM:PHASEMA(0rw)	HB60:BXBCM:ATTENC2(0rw)	HB60:BNCHCURR:RATIO:RBCK(0rw)
> 	HB60:DCCT:HALFLIFE(0rw)	LB60:BNCHCURR:RATIO(0rw)	LB60:BXBCM:ATTENC10(0rw)
> 	LB60:BXBCM:ATTENM1(0rw)	LB60:DCCT:INTCURR(0rw)
> Client Name="epicscp", Client Host="opi00gtw00", V4.8, Channel Count=0
> 	TId=0XA1D5B0, Protocol=TCP, Socket FD=52
> 	Secs since last send 334552.13, Secs since last receive 334553.13
> 	Remote Address 172.19.55.48 Remote Port 58592 State=up
> 	32914 bytes allocated
> 	TId=0X9BA254, Protocol=TCP, Socket FD=30
> 	Secs since last send 321961.78, Secs since last receive 321961.78
> 	Remote Address 172.19.55.48 Remote Port 58949 State=up
> Client Name="epicscp", Client Host="opi00gtw00", V4.7, Channel Count=43
> 	TId=0XA1ACFC, Protocol=TCP, Socket FD=59
> 	Secs since last send 173079.92, Secs since last receive 173079.91
> 	Unprocessed request bytes=3040, Undelivered response bytes=288
> 	Remote Address 172.19.55.48 Remote Port 59160 State=up
> 	38822 bytes allocated
> 	HB60:RING(1rw)	HB60:STATE:MSG1(1rw)	HB60:STATE:STOP(1rw)
> 	HB60:STATE:ACT(1rw)	HB60:BNCHCURR:SUMY:MA(1rw)	HB60:BNCHCURR:SUMY(1rw)
> 	HB60:DCCT:SUMY(1rw)	HB60:DCCT:DIDT(1rw)	HB60:DCCT:LIFETIME(1rw)
> 	HB60:INJECT:CAL:SUMSTAT(1rw)	HB60:INJECT:CAL:SUMSTAT(1rw)	HB60:FILL:GOAL:STATUS(1rw)
> 	HB60:MPG:STAT(1rw)	HB60:MPG:STAT(1rw)	HB60:DECAY:TIMEBASE:ACT(1rw)
> 	HB60:BNCHCURR:FILL:NUMBUCK(1rw)	HB60:DCCT:RAWTIME(1rw)	PB60:INJECT:BBR:STATUS(1rw)
> 	HB60:BNCHCURR:BXBTRIGR(1rw)	HB60:DCCT:CHIST(1rw)	HB60:DCCT:LHIST(1rw)
> 	HB60:INJECT:SPACE(1rw)	HB60:DECAY:TIMEBASE:REQ(1rw)	HB60:DECAY:TIMEBASE:ACT(1rw)
> 	HB60:DECAY:LINEAR:REQ(1rw)	HB60:STATE:MPGSHORT(1rw)	HB60:STATE:MPGLONG(1rw)
> 	HB60:DECAY:FITRVAL(1rw)	HB60:STATE:MPGHEAD(1rw)	HB60:DCCT:LIFEMAX(1rw)
> 	HB60:DCCT:CUTOFF(1rw)	HB60:DCCT:DISABLE(1rw)	HB60:DCCT:BEAMON(1rw)
> 	HB60:BNCHCURR:FILL:THRESH(1rw)	HB60:MPG:INSERTP(1rw)	HB60:MPG:PROCP(1rw)
> 	HB60:INJECT:RATE(1rw)	HB60:MPG:ADDRESS(0rw)	HB60:DECAY:TIMEBASE:MAX(0rw)
> 	HB60:STATE:RESET(0rw)	HB60:MPG:SATISP(0rw)	HB60:INJECT:BURST(0rw)
> 	HB60:RING(0rw)
> Client Name="epicscp", Client Host="opi00gtw00", V4.8, Channel Count=14
> 	TId=0X93BC28, Protocol=TCP, Socket FD=43
> 	Secs since last send   0.38, Secs since last receive   5.92
> 	Remote Address 172.19.55.48 Remote Port 59163 State=up
> 	34986 bytes allocated
> 	HB60:BNCHCURR:HILIM(1rw)	HB60:BNCHCURR:LOWLIM(1rw)	HB60:BNCHCURR:EVENPED(1rw)
> 	HB60:DCCT:RAWTIME(1rw)	HB60:BNCHCURR:MAXCURR(1rw)	HB60:BNCHCURR:MAXADC(1rw)
> 	HB60:BNCHCURR:SUMY(1rw)	HB60:BNCHCURR:BXBTRIGR(1rw)	HB60:BNCHCURR:COMP(1rw)
> 	HB60:XAXIS:COMP(1rw)	HB60:BNCHCURR:MIDP(1rw)	HB60:BNCHCURR:BXBTRIGR(1rw)
> 	HB60:BNCHCURR:EXP:Y(1rw)	HB60:BNCHCURR:EXP:X(1rw)
> Client Name="epicscp", Client Host="opi00gtw00", V4.7, Channel Count=21
> 	TId=0XC42A1C, Protocol=TCP, Socket FD=49
> 	Secs since last send   0.37, Secs since last receive 257728.80
> 	Remote Address 172.19.55.48 Remote Port 59238 State=up
> 	36022 bytes allocated
> 	TId=0X9BF164, Protocol=TCP, Socket FD=54
> 	Secs since last send 167216.27, Secs since last receive 167216.28
> 	Remote Address 172.19.55.48 Remote Port 59458 State=up
> 	TId=0XAB6DAC, Protocol=TCP, Socket FD=46
> 	Secs since last send   0.12, Secs since last receive 32939.46
> 	Remote Address 172.19.55.48 Remote Port 59712 State=up
> 	LB60:RING(1rw)	LB60:STATE:MSG1(1rw)	LB60:STATE:STOP(1rw)
> 	LB60:STATE:ACT(1rw)	LB60:BNCHCURR:SUMY:MA(1rw)	LB60:BNCHCURR:SUMY(1rw)
> 	LB60:DCCT:SUMY(1rw)	LB60:DCCT:DIDT(1rw)	LB60:DCCT:LIFETIME(1rw)
> 	LB60:INJECT:CAL:SUMSTAT(1rw)	LB60:INJECT:CAL:SUMSTAT(1rw)	LB60:FILL:GOAL:STATUS(1rw)
> 	LB60:MPG:STAT(1rw)	LB60:MPG:STAT(1rw)	LB60:DECAY:TIMEBASE:ACT(1rw)
> 	LB60:BNCHCURR:FILL:NUMBUCK(1rw)	LB60:DCCT:RAWTIME(1rw)	PB60:INJECT:BBR:STATUS(1rw)
> 	LB60:BNCHCURR:BXBTRIGR(1rw)	LB60:DCCT:CHIST(1rw)	LB60:DCCT:LHIST(1rw)
> 	TId=0XC0CE10, Protocol=TCP, Socket FD=10
> 	Secs since last send 94117.98, Secs since last receive 94118.00
> 	Remote Address 172.19.55.48 Remote Port 59744 State=up
> 	TId=0XC22AF0, Protocol=TCP, Socket FD=27
> 	Secs since last send   0.43, Secs since last receive 10466.22
> 	Remote Address 172.19.55.48 Remote Port 59921 State=up
> 	33210 bytes allocated
> 	HB60:DCCT:SUMY(1rw)	HB60:RF:CUTOFF(1rw)
> Client Name="vxworks", Client Host="rfs08her01", V4.8, Channel Count=1
> 	TId=0X98506C, Protocol=TCP, Socket FD=32
> 	Secs since last send 74326.00, Secs since last receive 74326.00
> 	Remote Address 172.19.55.64 Remote Port 1036 State=up
> 	HB60:RF:BEAMON(1rw)
> Client Name="vxworks", Client Host="cen-bip", V4.6, Channel Count=16
> 	TId=0XC321A4, Protocol=TCP, Socket FD=29
> 	Secs since last send 72878.87, Secs since last receive 72878.87
> 	Unprocessed request bytes=0, Undelivered response bytes=128
> 	Remote Address 134.79.158.20 Remote Port 1026 State=up
> 	34598 bytes allocated
> 	LB60:STATE:MSG1(1rw)	HB60:STATE:MSG1(1rw)	LB60:STATE:ACT(1rw)
> 	LB60:MPG:STAT(1rw)	LB60:INJECT:CAL:SUMSTAT(1rw)	HB60:STATE:ACT(1rw)
> 	HB60:MPG:STAT(1rw)	HB60:INJECT:CAL:SUMSTAT(0rw)	LB60:BNCHCURR:BXBTRIGR(0rw)
> 	HB60:BNCHCURR:BXBTRIGR(0rw)	LB60:FILL:GOAL:STATUS(0rw)	HB60:FILL:GOAL:STATUS(0rw)
> 	PB60:MEMORY:USED(0rw)	LB60:BNCHCURR:SUMY:MA(0rw)	LB60:BNCHCURR:SUMY(0rw)
> Client Name="vxworks", Client Host="cen-bip", V4.6, Channel Count=14
> 	TId=0XC458B0, Protocol=TCP, Socket FD=31
> 	Secs since last send   0.42, Secs since last receive 72877.37
> 	Remote Address 134.79.158.20 Remote Port 1028 State=up
> 	34758 bytes allocated
> 	HB60:DCCT:LIFETIME(1rw)	HB60:DCCT:SUMY(1rw)	HB60:BNCHCURR:SUMY(1rw)
> 	HB60:BNCHCURR:SUMY:MA(1rw)	HB60:BNCHCURR:RATIO:RBCK(1rw)	HB60:DCCT:DIDT(1rw)
> 	HB60:BNCHCURR:BXBTRIGR(1rw)	HB60:STATE:MSG1(1rw)	HB60:INJECT:CAL:SUMSTAT(1rw)
> 	HB60:STATE:ACT(1rw)	HB60:MPG:STAT(1rw)	HB60:FILL:GOAL:STATUS(0rw)
> 	LB60:DCCT:LIFETIME(0rw)	LB60:DCCT:SUMY(0rw)
> 	TId=0XB9FBBC, Protocol=TCP, Socket FD=14
> 	Secs since last send 72618.07, Secs since last receive 72617.88
> 	Unprocessed request bytes=3256, Undelivered response bytes=288
> 	Remote Address 172.19.55.48 Remote Port 60056 State=up
> 	35338 bytes allocated
> 	HB60:MPG:STAT(0rw)	HB60:MPG:STAT(0rw)	HB60:DECAY:TIMEBASE:ACT(0rw)
> 	HB60:BNCHCURR:FILL:NUMBUCK(0rw)	HB60:DCCT:RAWTIME(0rw)	PB60:INJECT:BBR:STATUS(0rw)
> 	HB60:BNCHCURR:BXBTRIGR(0rw)	HB60:DCCT:CHIST(0rw)	HB60:DCCT:LHIST(0rw)
> 	TId=0XB97028, Protocol=TCP, Socket FD=53
> 	Secs since last send 72591.50, Secs since last receive 72591.43
> 	Unprocessed request bytes=3256, Undelivered response bytes=384
> 	Remote Address 172.19.55.48 Remote Port 60068 State=up
> Client Name="vxworks", Client Host="rfs08her05", V4.8, Channel Count=1
> 	TId=0XBA3B50, Protocol=TCP, Socket FD=35
> 	Secs since last send 62165.93, Secs since last receive 62165.93
> 	Remote Address 172.19.55.66 Remote Port 1036 State=up
> 	HB60:RF:BEAMON(1rw)
> 	TId=0XC17160, Protocol=TCP, Socket FD=36
> 	Secs since last send 61959.45, Secs since last receive 61959.18
> 	Unprocessed request bytes=3256, Undelivered response bytes=48
> 	Remote Address 172.19.55.48 Remote Port 61196 State=up
> 	TId=0XA7CF0C, Protocol=TCP, Socket FD=55
> 	Secs since last send 61897.68, Secs since last receive 61897.67
> 	Unprocessed request bytes=2784, Undelivered response bytes=432
> 	Remote Address 172.19.55.48 Remote Port 61200 State=up
> Client Name="epicscp", Client Host="opi00gtw00", V4.7, Channel Count=23
> 	TId=0X92ED60, Protocol=TCP, Socket FD=41
> 	Secs since last send 61530.43, Secs since last receive 61530.42
> 	Remote Address 172.19.55.48 Remote Port 61205 State=up
> 	35634 bytes allocated
> 	HB60:DCCT:SUMY(1rw)	HB60:RF:CUTOFF(1rw)	HB60:RING(1rw)
> 	HB60:STATE:MSG1(1rw)	HB60:STATE:STOP(1rw)	HB60:STATE:ACT(1rw)
> 	HB60:BNCHCURR:SUMY:MA(1rw)	HB60:BNCHCURR:SUMY(1rw)	HB60:DCCT:SUMY(1rw)
> 	HB60:DCCT:DIDT(1rw)	HB60:DCCT:LIFETIME(1rw)	HB60:INJECT:CAL:SUMSTAT(1rw)
> 	HB60:INJECT:CAL:SUMSTAT(1rw)	HB60:FILL:GOAL:STATUS(1rw)	HB60:MPG:STAT(0rw)
> 	HB60:MPG:STAT(0rw)	HB60:DECAY:TIMEBASE:ACT(0rw)	HB60:BNCHCURR:FILL:NUMBUCK(0rw)
> 	HB60:DCCT:RAWTIME(0rw)	PB60:INJECT:BBR:STATUS(0rw)	HB60:BNCHCURR:BXBTRIGR(0rw)
> 	TId=0X929BF8, Protocol=TCP, Socket FD=58
> 	Secs since last send 61486.46, Secs since last receive 61486.37
> 	Unprocessed request bytes=3288, Undelivered response bytes=336
> 	Remote Address 172.19.55.48 Remote Port 61208 State=up
> 	TId=0X924A90, Protocol=TCP, Socket FD=61
> 	Secs since last send   0.80, Secs since last receive 10253.43
> 	Remote Address 172.19.55.48 Remote Port 61214 State=up
> 	HB60:DCCT:SUMY(1rw)	LB60:DCCT:SUMY(1rw)
> 	TId=0X9221DC, Protocol=TCP, Socket FD=60
> 	Secs since last send 44343.75, Secs since last receive 44343.65
> 	Remote Address 172.19.55.48 Remote Port 61225 State=up
> 	TId=0X91D074, Protocol=TCP, Socket FD=62
> 	Secs since last send   0.10, Secs since last receive 37124.85
> 	Remote Address 172.19.55.48 Remote Port 61229 State=up
> 	TId=0X917F0C, Protocol=TCP, Socket FD=63
> 	Secs since last send 8166.55, Secs since last receive 8167.57
> 	Remote Address 172.19.55.48 Remote Port 61282 State=up
> 	TId=0X912DA4, Protocol=TCP, Socket FD=65
> 	Secs since last send 8052.22, Secs since last receive 8052.17
> 	Remote Address 172.19.55.48 Remote Port 61291 State=up
> 	TId=0X9028D8, Protocol=TCP, Socket FD=66
> 	Secs since last send   0.98, Secs since last receive 2181.18
> 	Remote Address 172.19.55.48 Remote Port 61393 State=up
> 	TId=0X900024, Protocol=TCP, Socket FD=67
> 	Secs since last send 2148.77, Secs since last receive 2148.60
> 	Unprocessed request bytes=3256, Undelivered response bytes=144
> 	Remote Address 172.19.55.48 Remote Port 61402 State=up
> 	TId=0X8FD770, Protocol=TCP, Socket FD=70
> 	Secs since last send 1241.23, Secs since last receive 1241.12
> 	Remote Address 172.19.55.48 Remote Port 61417 State=up
> Client Name="COW05", Client Host="MCC.SLAC.Stanford.EDU", V4.8, Channel Count=4
> 	TId=0X8FAEBC, Protocol=TCP, Socket FD=71
> 	Secs since last send 252.48, Secs since last receive 252.48
> 	Remote Address 172.19.55.11 Remote Port 2508 State=up
> 	33202 bytes allocated
> 	LB60:DCCT:SUMY(0rw)	HB60:DCCT:SUMY(0rw)	LB60:DCCT:LIFETIME(0rw)
> Client Name="DMW", Client Host="MCC.SLAC.Stanford.EDU", V4.8, Channel Count=4
> 	TId=0XABEB90, Protocol=TCP, Socket FD=68
> 	Secs since last send 255.20, Secs since last receive 255.20
> 	Remote Address 172.19.55.11 Remote Port 2534 State=up
> 	LB60:DCCT:SUMY(0rw)	LB60:DCCT:SUMY(0rw)	HB60:DCCT:SUMY(0rw)
> 	HB60:DCCT:SUMY(0rw)
> Client Name="", Client Host="", V4.0, Channel Count=0
> 	TId=0XCCF9B0, Protocol=UDP, Socket FD=26
> 	Secs since last send 145.87, Secs since last receive   0.13
> 	Remote Address 172.19.55.11 Remote Port 4350 State=up
> There are currently 383522 bytes on the server's free list
> 9 client(s), 482 channel(s), and 692 event(s) (monitors)
> The server's resource id conversion table:
> Bucket entries in use = 542 bytes in use = 25076
> Bucket entries/hash id - mean = 0.132324 std dev = 0.338843 max = 1
> Channel Access Address List
> 172.19.55.255
> 134.79.158.20
> value = 14 = 0xe
> bic06pep00 -> dbcar(0,2)
>     connected 134.79.158.20 PB60:BBR:ABORT.INP CEN:BIP:BBR:ABORT.VAL nDisconnect 1
>     connected 134.79.158.20 PB60:BBR:INJDENY.INP CEN:BIP:BBR:DENY.VAL nDisconnect 1
>     connected 134.79.158.20 PB60:BBR:INJPMT.INP CEN:BIP:BBR:INJPMT.VAL nDisconnect 1
>     connected 134.79.158.20 PB60:BBR:INJSAFE.INP CEN:BIP:BBR:INJECT.VAL nDisconnect 1
>     connected 134.79.158.20 PB60:BBR:INJWAIT.INP CEN:BIP:BBR:WAIT.VAL nDisconnect 1
> not_connected HB60:INJECT:CALGOOS2.LNK1 HB60:INJECT:06NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOS2.LNK2 HB60:INJECT:07NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOS2.LNK3 HB60:INJECT:08NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOS2.LNK4 HB60:INJECT:09NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOS2.LNK5 HB60:INJECT:10NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOS3.LNK1 HB60:INJECT:11NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOS3.LNK2 HB60:INJECT:12NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOS3.LNK3 HB60:INJECT:13NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOS3.LNK4 HB60:INJECT:14NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOS3.LNK5 HB60:INJECT:15NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOS3.LNK6 HB60:INJECT:16NEWCAL.PROC nDisconnect 0
> not_connected HB60:INJECT:CALGOOSE.LNK5 HB60:INJECT:05NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS2.LNK1 LB60:INJECT:06NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS2.LNK2 LB60:INJECT:07NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS2.LNK3 LB60:INJECT:08NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS2.LNK4 LB60:INJECT:09NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS2.LNK5 LB60:INJECT:10NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS3.LNK1 LB60:INJECT:11NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS3.LNK2 LB60:INJECT:12NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS3.LNK3 LB60:INJECT:13NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS3.LNK4 LB60:INJECT:14NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS3.LNK5 LB60:INJECT:15NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOS3.LNK6 LB60:INJECT:16NEWCAL.PROC nDisconnect 0
> not_connected LB60:INJECT:CALGOOSE.LNK5 LB60:INJECT:05NEWCAL.PROC nDisconnect 0
> ncalinks 29 not connected 24 no_read_access 0 no_write_access 0
>  nDisconnect 5 nNoWrite 0
> value = 0 = 0x0
> bic06pep00 -> spy
> value = 10715336 = 0xa380c8
> bic06pep00 -> NAME          ENTRY         TID   PRI   total % (ticks)  delta % (ticks)
> tExcTask     _excTask     fddc20    0     0% (       0)    0% (       0)
> tLogTask     _logTask     fdb30c    0     0% (       0)    0% (       0)
> tShell       _shell       a4342c    1     0% (       0)    0% (       0)
> tRlogind     _rlogind     fa1e88    2     0% (       0)    0% (       0)
> tTelnetd     _telnetd     f9ffd0    2     0% (       0)    0% (       0)
> tRlogOutTask _rlogOutTa   90e19c    2     0% (       0)    0% (       0)
> tRlogInTask  _rlogInTas   90cc70    2     0% (       0)    0% (       0)
> tWdbTask                  f961d0    3     0% (       0)    0% (       0)
> tSpyTask     _spyComTas   a380c8    5     0% (       5)    0% (       5)
> tGpibQTask0  _ipGpibSca   d68788   47     5% (      28)    5% (      28)
> tAioIoTask1  _aioIoTask   fcedf0   50     0% (       0)    0% (       0)
> tAioIoTask0  _aioIoTask   fc7c4c   50     0% (       0)    0% (       0)
> t
> NetTask     _netTask     fbd610   50     0% (       4)    0% (       4)
> t
> AioWait     _aioWaitTa   fd5f94   51     0% (       0)    0% (       0)
> cbHigh       _callbackT   d6e660   51     0% (       0)    0% (       0)
> scan6                     cd390c   52     0% (       0)    0% (       0)
> scan12                    cd61e0   53     0% (       0)    0% (       0)
> scan30                    cd8ab4   54     0% (       0)    0% (       0)
> tFtpdTask    _ftpdTask    f9d578   55     0% (       0)    0% (       0)
> scan60                    cdb388   55     0% (       1)    0% (       1)
> scan120                   cddc5c   56     0% (       0)    0% (       0)
> cbMedium     _callbackT   d72e60   57     0% (       0)    0% (       0)
> scan300                   ce0530   57     0% (       0)    0% (       0)
> scan600                   ce2e04   58     0% (       0)    0% (       0)
> scan216000                ce56d8   59     0% (       0)    0% (       0)
> cbLow        _callbackT   d77660   65     2% (      12)    2% (      12)
> scanOnce                  ce89bc   65     0% (       0)    0% (       0)
> epicsPrint                eb06f0   70     0% (       0)    0% (       0)
> ts_Casync                 d52970   70     0% (       0)    0% (       0)
> EV tSaveRest _event_tas   c6b694   95     0% (       0)    0% (       0)
> tSaveRestore              c6ebd0   96     2% (      11)    2% (      11)
> EV seqAux    _event_tas   bbe158   98     0% (       0)    0% (       0)
> EV dbCaLink  _event_tas   d5722c   99     0% (       0)    0% (       0)
> seqAux       _seqAuxTas   bc7ca0   99     0% (       0)    0% (       0)
> tPortmapd    _portmapd    f9eaa4  100     0% (       0)    0% (       0)
> tErr         _err_masse   eb4694  100     0% (       0)    0% (       0)
> dbCaLink     _dbCaTask    d6b03c  100     0% (       0)    0% (       0)
> Bic_Babar    _sequencer   bbc1b0  100     0% (       0)    0% (       0)
> Bic_Proc_HER _sequencer   b41ff0  100     1% (       8)    1% (       8)
> Bic_Stat_HER _sequencer   b2f0b4  100     0% (       1)    0% (       1)
> HER_Bic_Bunc _sequencer   b12c88  100     9% (      47)    9% (      47)
> HER_Bic_Curr _sequencer   b0e0d0  100     0% (       0)    0% (       0)
> HER_Bic_Deca _sequencer   b072d4  100     0% (       1)    0% (       1)
> HER_Bic_Cals _sequencer   b038e8  100     0% (       0)    0% (       0)
> Bic_Proc_LER _sequencer   ab1148  100     0% (       5)    0% (       5)
> Bic_Stat_LER _sequencer   aa76d4  100     0% (       1)    0% (       1)
> LER_Bic_Bunc _sequencer   a8959c  100     9% (      48)    9% (      48)
> LER_Bic_Curr _sequencer   a84850  100     1% (      10)    1% (      10)
> LER_Bic_Deca _sequencer   a8128c  100     0% (       5)    0% (       5)
> LER_Bic_Cals _sequencer   a797c4  100     0% (       0)    0% (       0)
> RD dbCaLink  _cac_recv_   cc6354  101     0% (       5)    0% (       5)
> CA client    _camsgtask   c1ede0  180     0% (       0)    0% (       0)
> CA client    _camsgtask   c1afa0  180     0% (       0)    0% (       0)
> CA client    _camsgtask   bb3cf0  180     0% (       0)    0% (       0)
> CA client    _camsgtask   baf9f0  180     0% (       0)    0% (       0)
> CA client    _camsgtask   babadc  180     0% (       0)    0% (       0)
> CA client    _camsgtask   ba7b4c  180     0% (       0)    0% (       0)
> CA client    _camsgtask   b91a68  180     0% (       0)    0% (       0)
> CA client    _camsgtask   b4c3c8  180     0% (       0)    0% (       0)
> CA client    _camsgtask   abad50  180     0% (       0)    0% (       0)
> CA client    _camsgtask   a1d5b0  180     0% (       0)    0% (       0)
> CA client    _camsgtask   9ba254  180     0% (       0)    0% (       0)
> CA client    _camsgtask   a1acfc  180     0% (       0)    0% (       0)
> CA client    _camsgtask   93bc28  180     0% (       0)    0% (       0)
> CA client    _camsgtask   c42a1c  180     0% (       0)    0% (       0)
> CA client    _camsgtask   9bf164  180     0% (       0)    0% (       0)
> CA client    _camsgtask   ab6dac  180     0% (       0)    0% (       0)
> CA client    _camsgtask   c0ce10  180     0% (       0)    0% (       0)
> CA client    _camsgtask   c22af0  180     0% (       0)    0% (       0)
> CA client    _camsgtask   98506c  180     0% (       0)    0% (       0)
> CA client    _camsgtask   c321a4  180     0% (       0)    0% (       0)
> CA client    _camsgtask   c458b0  180     0% (       0)    0% (       0)
> CA client    _camsgtask   b9fbbc  180     0% (       0)    0% (       0)
> CA client    _camsgtask   b97028  180     0% (       0)    0% (       0)
> CA client    _camsgtask   ba3b50  180     0% (       0)    0% (       0)
> CA client    _camsgtask   c17160  180     0% (       0)    0% (       0)
> CA client    _camsgtask   a7cf0c  180     0% (       0)    0% (       0)
> CA client    _camsgtask   92ed60  180     0% (       0)    0% (       0)
> CA client    _camsgtask   929bf8  180     0% (       0)    0% (       0)
> CA client    _camsgtask   924a90  180     0% (       0)    0% (       0)
> CA client    _camsgtask   9221dc  180     0% (       0)    0% (       0)
> CA client    _camsgtask   91d074  180     0% (       0)    0% (       0)
> CA client    _camsgtask   917f0c  180     0% (       0)    0% (       0)
> CA client    _camsgtask   912da4  180     0% (       0)    0% (       0)
> CA client    _camsgtask   9028d8  180     0% (       0)    0% (       0)
> CA client    _camsgtask   900024  180     0% (       0)    0% (       0)
> CA client    _camsgtask   8fd770  180     0% (       0)    0% (       0)
> CA client    _camsgtask   8faebc  180     0% (       0)    0% (       0)
> CA client    _camsgtask   abeb90  180     0% (       0)    0% (       0)
> CA repeater               d5eab0  181     0% (       0)    0% (       0)
> CA TCP       _req_serve   cd0f3c  181     0% (       0)    0% (       0)
> CA event     _event_tas   c1c52c  181     0% (       0)    0% (       0)
> CA event     _event_tas   c186ec  181     0% (       0)    0% (       0)
> CA event     _event_tas   bb143c  181     1% (       6)    1% (       6)
> CA event     _event_tas   bad068  181     0% (       0)    0% (       0)
> CA event     _event_tas   ba90d8  181     0% (       0)    0% (       0)
> CA event     _event_tas   ba5138  181     0% (       0)    0% (       0)
> CA event     _event_tas   b4ebc8  181     0% (       0)    0% (       0)
> CA event     _event_tas   b499d4  181     0% (       2)    0% (       2)
> CA event     _event_tas   ab849c  181     0% (       0)    0% (       0)
> CA event     _event_tas   9bb7e0  181     0% (       0)    0% (       0)
> CA event     _event_tas   97e6d8  181     0% (       0)    0% (       0)
> CA event     _event_tas   a7e498  181     0% (       0)    0% (       0)
> CA event     _event_tas   9cda64  181     0% (       2)    0% (       2)
> CA event     _event_tas   c0e39c  181     0% (       0)    0% (       0)
> CA event     _event_tas   97fee0  181     0% (       0)    0% (       0)
> CA event     _event_tas   938e6c  181     0% (       1)    0% (       1)
> CA event     _event_tas   a40908  181     0% (       0)    0% (       0)
> CA event     _event_tas   9a7fd4  181     0% (       0)    0% (       0)
> CA event     _event_tas   9827b8  181     0% (       0)    0% (       0)
> CA event     _event_tas   c2f8f0  181     0% (       0)    0% (       0)
> CA event     _event_tas   c78eb0  181     0% (       2)    0% (       2)
> CA event     _event_tas   9a19cc  181     0% (       0)    0% (       0)
> CA event     _event_tas   9b782c  181     0% (       0)    0% (       0)
> CA event     _event_tas   99d544  181     0% (       0)    0% (       0)
> CA event     _event_tas   c7b664  181     0% (       0)    0% (       0)
> CA event     _event_tas   994210  181     0% (       0)    0% (       0)
> CA event     _event_tas   98db1c  181     0% (       0)    0% (       0)
> CA event     _event_tas   9b1844  181     0% (       0)    0% (       0)
> CA event     _event_tas   b93084  181     0% (       0)    0% (       0)
> CA event     _event_tas   99fe98  181     0% (       0)    0% (       0)
> CA event     _event_tas   92c4ac  181     0% (       0)    0% (       0)
> CA event     _event_tas   98f5b4  181     0% (       0)    0% (       0)
> CA event     _event_tas   b94774  181     0% (       0)    0% (       0)
> CA event     _event_tas   9154e4  181     0% (       1)    0% (       1)
> CA event     _event_tas   927344  181     0% (       0)    0% (       0)
> CA event     _event_tas   a22604  181     0% (       0)    0% (       0)
> CA event     _event_tas   8b816c  181     0% (       0)    0% (       0)
> CA event     _event_tas   91f640  181     0% (       0)    0% (       0)
> CA UDP       _cast_serv   ccf9b0  182     0% (       1)    0% (       1)
> CA online    _rsrv_onli   cc0bec  183     0% (       0)    0% (       0)
> logRestart                da3fb8  200     0% (       0)    0% (       0)
> taskwd                    da2da8  200     0% (       0)    0% (       0)
> cpuUsageTask              d55538  255    43% (     218)   43% (     218)
> KERNEL                                    1% (       6)    1% (       6)
> INTERRUPT                                 0% (       0)    0% (       0)
> IDLE                                     14% (      74)   14% (      74)
> TOTAL                                    88% (     506)   88% (     506)
> 1 task was created.
> bic06pep00 -> logout
> Connection closed
>   LUCHINI      logged out at 10-NOV-1998 10:49:43.02
Prev: Motor Record V3.4 release. Ron Sluiter
Next: CA Server link error w/channel access control John A. Priller
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
