1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: XyCom XVME-566 adc problem.
To: tech talk <[email protected]>
Date: Thu, 12 Nov 1998 08:03:42 -0800
I've run into a problem with the xvme-566 adc.  If I try to use
it in either of the differential input modes I get an error from the
driver at iocInit time.  We want to use it in "scanned-differential"
mode.
The error message is:
  PV: blioc402:diffAdc000 devAiXy566Di (init_record) ai_xy566_driver
error
I've looked at the driver and it seems like it should ought to work, but
since it doesn't, I must be missing something.  Does anyone have any
ideas?
Let's see ... R3.13.0b12, mv162, the board works fine in single-ended
mode
(which probably won't be good enough for this application), vxWorks 5.2.
The record is attached.
TIA!
Disclaimer:  Any opinions are my own and have	  | -bill
  nothing to do with the official policy or the   |  [email protected]
  management of L.B.N.L, who probably couldn't    |  Berkeley, CA
  care less about employees who play with trains. |  aka
[email protected]
grecord(ai,"blioc402:diffAdc000") {
	field(DESC,"Gen. Purp. ADC 0-0")
	field(SCAN,".1 second")
	field(DTYP,"XYCOM-566 Dif Scanned")
	field(DISS,"MAJOR")
	field(INP,"#C0 S0 @")
	field(PREC,"3")
	field(LINR,"LINEAR")
	field(EGUF,"2..")
	field(EGUL,"-2.o")
	field(EGU,"V.")
	field(HOPR,"2.0")
	field(LOPR,"-2.0")
Prev: epics problem Eugene T. Yamamoto
Next: Re: XyCom XVME-566 adc problem. Bill Brown
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
