1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: SNL request
To: [email protected], [email protected], [email protected], [email protected]
Date: Tue, 3 Nov 1998 16:55:23 -0800 (PST)
> >> It sure would be nice to have an option in the sequencer that would
> >> use ca_put_callback() ... i.e. a call that wouldn't return until
> >> record processing caused by the 'put' was complete. I'm trying to work
> >> with a device that is quite unpredictable in its response time.
> >It would also be nice to get a 'done' event corresponding to a 'put'
> >without hanging at the 'put' call.
> I agree with both suggestions. ca_put_callback() really should be supported
> and you really shouldn't have to block until the callback has been delivered.
> Off the top of my head, how about the following spec:
> pvPut( var );		/* existing behavior */
> pvPut( var, wait );	/* use ca_put_callback(); if wait==TRUE, block on
> 			   completion with some pre-determined timeout */
> pvPut( var, wait, timeout );
> 			/* as above but specify the timeout */
> if wait==FALSE, pvPut() will not block and completion can be checked by using
> when ( pvPutDone( var ) ) {
> which will fail if no put is active, or wait for put completion otherwise.
> Timeouts can be handled using the normal delay() mechanism. There would
> probably also need to be a pvPutActive( var ) enquiry function.
> I can't make any statement about when this might get done (assuming that
> no-one gets there before I do). I would prefer to make this change only to
> the still-unleased version that has the PV queueing facilities. We have been
> using this operationally for several years.
> Comments?
1) I agree you should combine this with your PV-queue capable version.
2) Above calling sequences are OK, however, I think I prefer
	pvPut( var )
	pvPutCallback( var, wait, timeout )
	pvPutDone( var )
  a) I prefer to stick with a fixed number of arguments for given calling name
  rather than C++-style "different args is different semantics".
  b) I think timeout should be specified--what would a "good" values
  be for timeout?
  c) presumably if you choose wait==FALSE and later call pvPutDone(), when
  the original timeout expires it also fails, but with E_TIMED_OUT
  instead of E_NOT_WAITING.  And if it has succeeded already it returns
  OK, just as it does for normal unblocking?
--Steve
Prev: RE: Epics build for Multiple Host Architectures? Mark Rivers
Next: Re: Frame grabber and Portable channel access Brian Tieman
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: SNL request William Lupton
Next: Re: SNL request William Lupton
