> Here is what we put in st.cmd to get IOCs to be able to talk both to the
> outside world and to each other:
> routeAdd "0","164.54.160.1"
> routeDelete "164.54.160.0","164.54.160.1"
> which, as I understand it first tells the IOC to go to 160.1 for all
> connections, but then says that any connections on the local subnet should not
> go through this router.
I don't recommend giving VxWorks such a wide-open default, for security reasons.
Unless your router itself (164.54.160.1 in the example above) is carefully
configured--or some external router beyond that is acting as a serious
firewall--you are open to many attacks using TCP. VxWorks is not very
secure (although it is quite *OBSCURE*). I do recommend adding just: 1) host
routes to specific hosts that you intend to use CA; and 2) net routes to nets
that you know are truly secure--and have intended CA hosts on them.
IOC communication Mark Rivers
Power PC floating point underflow William Lupton
<1998>
<1998>
