Sorry I waited so long to respond.
Paul Sichta wrote:
> To all :
> OK, Thanks for helping me understand the mbbi/hardware/soft
> device/shift/mask stuff better.
> Proposal number 2 is to modify the device support module devMbbiSoftRaw.c
> to mask the rval similar to the way hardware device support does it. The
> mask will be calculated from the NOBT and the user-specified SHFT fields.
> I have produced a test version of devMbbiSoftRaw.c and have tested it with
> CAMAC hardware and with soft raw device support. The hardware worked as
> before, and the soft raw support worked as desired, extracting only the
> "middle" bits of interest.
> Regarding changes to the devMbbiSoftRaw.c file :
> This could be added to the end of the init_record section :
> /* initialize mask*/
> pmbbi->mask = 0;
> for (i=0; i<pmbbi->nobt; i++) {
> pmbbi->mask <<= 1; /* shift left 1 bit*/
> pmbbi->mask |= 1; /* set low order bit*/
> pmbbi->mask <<= pmbbi->shft;
For the mbbi record the above can be replaced by
because mbbiRecord.c already computes mask.
> This could be added to the read_mbbi section following dbGetLink :
> if(status==0) pmbbi->rval = pmbbi->rval & pmbbi->mask;
> Regarding legacy mbbi records which use raw soft device support: If a
> legacy mbbi record had used bits "beyond" the specified NOBT as part of
> their
> state values, then the record will produce a different result because
> the bits beyond NOBT will (now) be masked.
This is a concern. What Paul is recommending sounds good. It certainly
makes the binary soft raw support do what is expected with mask,shft.
But what about existing applications that may break? I dont know what to
recommend.
If we make this change then the following should all be changed to use
mask,shft.
devBiSoftRaw, devBoSoftRaw, devMbbiDirectSoftRaw, devMbbiSoftRaw,
devMbboDirectSoftRaw, devMbboSoftRaw
Marty Kraimer
- Re: MBBI & mask Paul Sichta
PEP VM162 and VM172 Stephen Pate
Wavetex 395 Jan Chrin
<1998>
beta12 & GPIB & Compiler Bug Marty Kraimer
<1998>
