1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Waveform Scale Factors
To: [email protected], [email protected], [email protected]
Date: Wed, 30 Sep 1998 08:46:58 -0700 (PDT)
> I had the same problem and solved it by extending the waveform record
> with the following fields:
	[snip]
> Record support and device support for Tek TDS540/784C have been extended
> according to the new fields. The resulting record type is now called
> swfRecord (for Scalable WaveForm). If you are interested I will send you
> the sources.
	Sounds like a generally useful technique; can you post them
	somewhere so then I can add them to the "Records" WWW page?
--Steve
Prev: Re: Waveform Scale Factors Benjamin Franksen
Next: MVME147's and Epics Steve Hunt
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Motif 2.1 and EPICS Christopher Larrieu
