Benjamin Franksen wrote:
> Marty Kraimer wrote:
> > GPIB device support which is implemented by starting the John Winan's
> > template
> > has the statements:
> > static struct devGpibParmBlock devSupParams;
> > static struct devGpibParmBlock devSupParams = {
> > Note that this is legal ISO C but is not legal C++
> I searched the 'bible' (K&R: The C Programming Language) and found no
> hint as to what the result of this should be. If one judges according to
> logic, the compiler should reject that as a multiple definition error.
> But in reality it seems the compiler believes that the first definition
> is meant as a declaration (even without 'extern' keyword) and so accepts
> it.
K&R is not very clear about this "feature".
I found two other books which more clearly state that this is legal ISO
C but not legal C++.
C, A Reference Manual, Harbison and Steele, FORTH EDITION. Section 4.9.7
Defining and Referencing Declarations.
The C++ Programmintg Language, Bjarne Stroustrup, THIRD EDITION,
Appendix B, Page 818.
> However, IMO it is better to prefix the _declaration_ with 'extern'
> instead of 'static', i.e.
> extern struct devGpibParmBlock devSupParams;
This is a solution if each GPIB device support modules uses a new name
instead of devSupParams.
This solves compiler bug but does not solve the C++ incompatibility.
Another way is to move the initialization to init_dev_sup. Thus instead
of
static struct devGpibParmBlock devSupParms = {
&Hp54540aDebug, /* debugging flag pointer */
-1, /* set to -1 if the device does NOT respond to
writes */
TIME_WINDOW, /* # of clock ticks to skip after a device times
out */
NULL, /* hwpvt list head */
gpibCmds, /* GPIB command array */
NUMPARAMS, /* number of supported parameters */
4, /* magic SRQ param number (-1 if none) */
"devHp54540Gpib", /* device support module type name */
DMA_TIME, /* # of clock ticks to wait for DMA completions
NULL, /* pointer to SRQ handler function (NULL if
none) */
NULL /* pointer to secondary conversion routine */
We could have
static long init_dev_sup(int parm)
devSupParms.debugFlag = &Hp54540aDebug;
devSupParms.respond2Writes = -1;
This still does not solve the problem that all existing support will
need to be modified.
I still hope we can fix the problem with a later version of GNU C.
Marty Kraimer
- beta12 & GPIB & Compiler Bug Marty Kraimer
- Re: beta12 & GPIB & Compiler Bug Benjamin Franksen
Re: Channel counts? Karen S. White
32 channel PMAC boards William Lupton
<1998>
<1998>
