To all :
OK, Thanks for helping me understand the mbbi/hardware/soft
device/shift/mask stuff better.
Proposal number 2 is to modify the device support module devMbbiSoftRaw.c
to mask the rval similar to the way hardware device support does it. The
mask will be calculated from the NOBT and the user-specified SHFT fields.
I have produced a test version of devMbbiSoftRaw.c and have tested it with
CAMAC hardware and with soft raw device support. The hardware worked as
before, and the soft raw support worked as desired, extracting only the
"middle" bits of interest.
Regarding changes to the devMbbiSoftRaw.c file :
This could be added to the end of the init_record section :
/* initialize mask*/
pmbbi->mask = 0;
for (i=0; i<pmbbi->nobt; i++) {
pmbbi->mask <<= 1; /* shift left 1 bit*/
pmbbi->mask |= 1; /* set low order bit*/
pmbbi->mask <<= pmbbi->shft;
This could be added to the read_mbbi section following dbGetLink :
if(status==0) pmbbi->rval = pmbbi->rval & pmbbi->mask;
Regarding legacy mbbi records which use raw soft device support: If a
legacy mbbi record had used bits "beyond" the specified NOBT as part of
their
state values, then the record will produce a different result because
the bits beyond NOBT will (now) be masked.
Regarding part 2 of my earlier posting, during the IOC boot I was loading
another application library *after* the library which was rebuilt with the
revised record support. The second library had the original .o files (with
identical names).
-ps
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477
- Re: MBBI & mask Marty Kraimer
Re: beta12 & GPIB & Compiler Bug Benjamin Franksen
Re: Channel counts? Bill McDowell
<1998>
Re: MBBI & mask Rozelle Wright
<1998>
