Li Jingyi wrote:
> Hi all,
> We have a newely bought Mvme167-35B card with 32MB memory.
> When I plug it in the crate and boot, the system halt.
> The vxWorks we currently use is 5.1 version. The following
> is the information on the console:
> boot device : ei
> processor number : 0
> host name : joca
> file name : /usr/VxWorks_5.1/vw/config/mv167/vxWorks
> inet on ethernet (e) : 152.3.54.5:ffffff00
> host inet (h) : 152.3.54.3
> user (u) : epics
> flags (f) : 0x0
> target name (tn) : orbit
> startup script (s) : /usr/applications/ioc/st.cmdmv167
> Attaching network interface ei0... done.
> Attaching network interface lo0... done.
> Loading... 369412 + 103168 + 26458
> Starting at 0x1000...
> Has anyone ever met such a problem and can give me some advise?
Seen this too many times ...
suggestions:
- check if you have an .rhosts file, and if the host that you are
booting from is in it
- check that you DON't have a line
setenv EPICS_CA_AUTO_ADDR_LIST "NO"
(and a subsequent EPICS_CA_ADDR_LIST that doesn't include both host
and crate) in your .login file
- check that your startup script doesn't have access restrictions in it
(but that, by itself, would make it halt later if I remember correctly)
Hope this helps,
Maren Purves
(it shouldn't be dependent on architecture)
- Mvme167-35b Li Jingyi
Re: Mvme167-35b Li Jingyi
<1998>
<1998>
