Ralph Lange wrote:
> > > The only problem could be Raw Soft Support, as there is no address
> > > information in the INP/OUT fields and SHFT will always be 0. Right?
> > But if SHFT were allowed to be set by GDCT, wouldn't it just be
> > overwritten by the device support layer in the cases where the device
> > support sets this field, thus making it work for all cases?
> Yup. I neither see any problems with the SHFT value made DCT accessible.
> What do you think, Marty?
I dont see a problem except that it may be confusing.
> Another workaround (as SHFT is DB accessible):
> Put a couple of dbpf commands at the end of the startup.command script
> (after iocInit) to set the SHFT fields.
I think I prefer this as a solution because using raw soft support will
not be used very often.
Note that this discussion also applys to mbbiRecord and mbboRecord as
well as to mbbiDirectRecord and mbboDirectRecord.
Marty Kraimer
- Re: MBBI, SHFT, and GDCT Ralph Lange
Re: MBBI, SHFT, and GDCT Tim Mooney
<1998>
Re: MBBI, SHFT, and GDCT Paul Sichta
<1998>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
