1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MBBI, SHFT, and GDCT
To: Paul Sichta <[email protected]>
Date: Fri, 14 Aug 1998 16:27:07 +0100
Paul Sichta wrote:
> I am using gdct313 to define an MBBI record and there is no place on the
> "Edit Attributes" form for specifying the number of bits to 'shift' the raw
> value (SHFT).  mbbiRecord.dbd does not assign the SHFT field to a
> promptgroup.  Is there a reason for this omission ?
The SHFT field is filled in by the device support layer automatically.
In your database you should just set the INP field to give the Card and
Signal number (or whatever address specification is used by your
particular device) of the lowest bit used, and set NOBT to the number of
bits to read.  The same applies to the other binary record types.
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
MBBI, SHFT, and GDCT Paul Sichta
Prev: MBBI, SHFT, and GDCT Paul Sichta
Next: Re: MBBI, SHFT, and GDCT Ralph Lange
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
