Hi. We have been attempting to run Resman on our baja 68060, but we run
out of memory. We don't think it is a software problem, as the program runs
just fine on a similar system. Here is our output:
-> < st.resman
resman(0, 0, 5, "/home/creek/best/sqeapp/iocBoot/ioctest",1)
Grand Interconnect VXI Resource Manager version 2.1 beta 3 (7/18/96)
Copyright (c) 1995, 1996, KineticSystems Corporation.
For help, use -h option.
Path to RM tables is </home/creek/best/sqeapp/iocBoot/ioctest>
Path to RM tables is </home/creek/best/sqeapp/iocBoot/ioctest/>
0x1eb80e0 (tShell): memPartAlloc: block too big - 84 in partition 0xa02e8.
* Warning: Could not create a nonvxi entry: S_memLib_NOT_ENOUGH_MEMORY
Access Fault
Program Counter: 0x00077580
Status Register: 0x3000
Access Address : 0x48562c4f
Fault Status : 0x01450020
8c9e _vxTaskEntry +10 : _shell (1, 0, 0, 0, 0, 0, 0, 0, 0, 0)
2d236 _shell +12a: 2d254 ([1, 0, 3, 7f, 0])
2d3c8 _shell +2bc: _execute ([1eb8002, 1, 0, 0, &_ioGlobalStdSet])
2d4a8 _execute +68 : 2d254 ([0, 0, 1, ffffffff, 1eb8002])
2d3c8 _shell +2bc: _execute ([1eb7f3a, 0, c, c, &_ioGlobalStdGet])
2d4e2 _execute +a2 : _yyparse ([0, 0, ffffffff, 1eb7f3a, 1eb8002])
861da _yyparse +520: 84bc6 (1eefc28, 1eefc48)
84cca _yystart +728: _resman (0, 0, 5, 1ffd944, 1, 0, 0, 0, 0, 0, 0, 0)
1e81994 _resman +28 : _rmShell ([0, 0, 5, 1ffd944, 2])
1e82212 _rmShell +168: _getnonVxi ([1eb79ec, &_yyval, d, c, 1])
1e81b02 _getnonVxi +bc : _abort (1eef8a8, 1e819dd)
1629c _abort +8 : _raise ([6, 1eb7998, 1e81b08, 1eef8a8, 1e819dd])
25772 _raise +e : _kill ([1eb80e0, 6, 1eb7874, 162a2, 6])
2585a _kill +e2 : 25fb4 ([1eb80e0, 6, 0, 1eef8a8, 1eb7868])
25fd0 _sigPendDestroy+90 : 25c30 ([1eb80e0, 1eb781c, d, c, 6])
25e48 _sigqueue +5d6: _sigqueue ([1eb779c, 1eb77b4, 1, 1eef57c, d])
25a36 _sigqueue +1c4: _shellRestart (6, 0, 1eb779c)
2d0b0 _shellRestart +a8 : _trcStack ([1e922, &_dbgPrintCall, 1eb80e0, 2d06a,
6])
7726c _trcStack +28 : 77560 ([48562c4f, 1eb80e0, 20, 1eb80e0, 1eb779c])
shell restarted.
-> 0x1ef5eb8 (tPortmapd): memPartAlloc: block too big - 1200 in partition
0xa02e8.
0x1ef5eb8 (tPortmapd): panic: rpc: svc_getreq: out of memory.
Here is the code we are using to allocate the memory. An example of
this is in the Tornado manuals.
/* a32 space (some more, R.Q., 4/28/97, extra needed for one V200) */
(void *) 0x42000000,
0x02000000, /* 32 Mbytes */
VM_STATE_MASK_VALID | VM_STATE_MASK_WRITABLE | VM_STATE_MASK_CACHEABLE,
VM_STATE_VALID | VM_STATE_WRITABLE | VM_STATE_CACHEABLE_NOT
/* a32 space (some more, R.Q., for second V200) */
(void *) 0x44000000,
/* a32 space (some more, R.Q., also for second V200) */
(void *) 0x46000000,
There are about 17 more of these 8 line statements of varying sizes.
Usually they are around 32 Mbytes, but the later ones are the Flash ROM, and are
around 512k.
Resman is a resource manager. It allocates extra memory in the 68060
for more programs and data. As you can see, it says that the memory block is
too big, which we assume means we ran out of memory. From what we've been told,
we shouldn't have run out of memory. Any ideas on why this is and/or how to fix
it would be appreciated. Thanks.
Donner
- Re: Resman problems... Andrew Johnson
RE: R3.13.0.beta12 and C++ libraries Jeff Hill
<1998>
Meeting in Berlin. Bob Dalesio
<1998>
