1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: R3.13.0.beta12 and C++ libraries
To: "'Sergey Kuznetsov'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 6 Aug 1998 13:39:41 -0600
Sergev,
It appears that you are using GNU gcc/g++ version 2.8.0. The gdd code is compiled/linked correctly
by the GNU tools on our system with the following version numbers.
EPICS R3.13.0.beta12
% uname -a
SunOS kingjohn 5.6 Generic sun4u sparc SUNW
% g++ -v
Reading specs from /usr/local/lib/gcc-lib/sparc-sun-solaris2.6/2.8.1/specs
gcc version 2.8.1
I have heard that early versions of gcc/g++ version 2.8 were quite buggy. It is possible that
you will need to upgrade to a current  release of gcc/g++ version 2.8. Also make certain that
your version of the gnu C++ standard library is compatible with your version of g++.
Jeff
On Wednesday, August 05, 1998 8:57 AM, Sergey Kuznetsov [SMTP:[email protected]] wrote:
> Hello all,
> We are compiling EPICS 3.13.0.beta12 with Tornado 1.0.1 under Solaris.
> We have compilation error:
> /usr/local/bin/g++ -ansi -pedantic -Wtraditional -o genApps -O  -Wall
> -Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings -Wconversion
> -Wstrict-prototypes -Wpointer-arith -Winline   -DSOLARIS   -DUNIX
> -DEXPL_TEMPL -I. -I..   -I../../../include
> -I../../../include/os/solaris           genApps.o gdd.o gddTest.o
> gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o
> aitHelpers.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o
> ld: fatal: symbol `__default_unexpected__Fv' is multiply defined:
>         (file /usr/local/lib/libstdc++.a(exceptioni.o) and file
> /usr/local/lib/gcc-lib/sparc-sun-solaris2.6/2.8.0/libgcc.a(exception.o));
> ld: fatal: symbol `terminate__Fv' is multiply defined:
> ld: fatal: symbol `set_terminate__FPFv_v' is multiply defined:
> ld: fatal: symbol `set_unexpected__FPFv_v' is multiply defined:
> ld: fatal: symbol `unexpected__Fv' is multiply defined:
> ld: fatal: File processing errors. No output written to genApps
> gmake[3]: *** [genApps] Error 1
> gmake[3]: Leaving directory `/users/epics/base/src/gdd/O.solaris'
> gmake[2]: *** [inc.solaris] Error 2
> gmake[2]: Leaving directory `/users/epics/base/src/gdd'
> gmake[1]: *** [gdd.inc] Error 2
> The   CONFIG_SITE  file  definitions are:
> #  Client ANSI C Compiler (for Host builds)
> #   GCC     (gcc -ansi) GNU
> #   ACC     (acc)       OS VENDOR
> #   HPACC   (cc -Aa)    OTHER VENDOR
> #ANSI=HPACC
> ANSI=GCC
> #  C++ Compiler (for Host builds)
> #   G++     (g++)   GNU C++
> #   CCC     (CC)    OS VENDOR C++
> #CPLUSPLUS=G++
> #Note: if CPLUSPLUS is empty then C++ src codes are not built
> #CPLUSPLUS= # use this if site does not have C++ compiler
> CPLUSPLUS=G++
> What is the right way to configure compiler?
> Many thanks,
>                                         Sergey Kuznetsov.
> SNS project
> [email protected]
Prev: Meeting in Berlin. Bob Dalesio
Next: Resman problems... donner
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: R3.13.0.beta12 and C++ libraries Sergey Kuznetsov
Next: Using PC to control CAMAC serial highway Lancaster, Christy A
