Hello all,
We are compiling EPICS 3.13.0.beta12 with Tornado 1.0.1 under Solaris.
We have compilation error:
/usr/local/bin/g++ -ansi -pedantic -Wtraditional -o genApps -O -Wall
-Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings -Wconversion
-Wstrict-prototypes -Wpointer-arith -Winline -DSOLARIS -DUNIX
-DEXPL_TEMPL -I. -I.. -I../../../include
-I../../../include/os/solaris genApps.o gdd.o gddTest.o
gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o
aitHelpers.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o
ld: fatal: symbol `__default_unexpected__Fv' is multiply defined:
(file /usr/local/lib/libstdc++.a(exceptioni.o) and file
/usr/local/lib/gcc-lib/sparc-sun-solaris2.6/2.8.0/libgcc.a(exception.o));
ld: fatal: symbol `terminate__Fv' is multiply defined:
ld: fatal: symbol `set_terminate__FPFv_v' is multiply defined:
ld: fatal: symbol `set_unexpected__FPFv_v' is multiply defined:
ld: fatal: symbol `unexpected__Fv' is multiply defined:
ld: fatal: File processing errors. No output written to genApps
gmake[3]: *** [genApps] Error 1
gmake[3]: Leaving directory `/users/epics/base/src/gdd/O.solaris'
gmake[2]: *** [inc.solaris] Error 2
gmake[2]: Leaving directory `/users/epics/base/src/gdd'
gmake[1]: *** [gdd.inc] Error 2
The CONFIG_SITE file definitions are:
# Client ANSI C Compiler (for Host builds)
# GCC (gcc -ansi) GNU
# ACC (acc) OS VENDOR
# HPACC (cc -Aa) OTHER VENDOR
#ANSI=HPACC
ANSI=GCC
# C++ Compiler (for Host builds)
# G++ (g++) GNU C++
# CCC (CC) OS VENDOR C++
#CPLUSPLUS=G++
#Note: if CPLUSPLUS is empty then C++ src codes are not built
#CPLUSPLUS= # use this if site does not have C++ compiler
CPLUSPLUS=G++
What is the right way to configure compiler?
Many thanks,
Sergey Kuznetsov.
SNS project
[email protected]
RE: CAMAC 2992 hangs vmebus Eric Bjorklund, NPSM
Using PC to control CAMAC serial highway Lancaster, Christy A
<1998>
RE: R3.13.0.beta12 + PPC MV2306 + VxWorks 5.3.1 (Tornado 1.0.1) + Solaris 2.6 Jeff Hill
RE: R3.13.0.beta12 and C++ libraries Jeff Hill
<1998>
