1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CAMAC 2992 hangs vmebus
To: <[email protected]>
Date: Mon, 3 Aug 1998 17:11:29 -0400
I am having problems with a Hytec VSD2992 CAMAC Serial Highway Driver.  I am
using the LANL driver software.
The module works fine when the CAMAC link is working.  If I momentarily
disconnect the link or otherwise try to generate link errors,  the MVME177
hangs with its VMEbus LED stuck on.  Channel Access disconnects and I can't
access the '177 from the local console.  The 2992 LEDS show errors and LAMs.
Reconnecting the CAMAC link back doesn't help,  the only way to resume
operation is to reboot the '177.
This is my 3rd 2992 and the first two never exhibit this problem.  Hytec has
the problematic 2992 and claim "it works here (in the U.K.)".  They  are
claiming that I must be configuring the 2992's registers to generate
interrupts ,  which are not being serviced properly.
  1)  Is the '177 hung or is it continually servicing a (high priority) VME
interrupt?
  2)  Is there a way to disable ISR's from the 2992 ?
  3)  How can I track what's going on in either the '177 or in the 2992
software driver.
-ps
Prev: fix for a VXI addressing bugs in dbStaticLib Rozelle Wright
Next: R3.13.0.beta12 + PPC MV2306 + VxWorks 5.3.1 (Tornado 1.0.1) + Solaris 2.6 Martí Pi
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: CAMAC 2992 hangs vmebus Eric Bjorklund, NPSM
