The card has two memory areas - one in short address space and one in
standard adress space. There are also 3 different types supported for the
xy566:
single ended, differential, and latched. The base addresses are specified
in module_types.h for short address space as:
0x6000, 0x7000, 0xe000
for standard address space they are
0x00000, 0x40000, 0xc0000
The code producing the error is in drvXy566.c
/* map the io card into the VRTX short address space */
status = sysBusToLocalAdrs(VME_AM_SUP_SHORT_IO, base_addr, &pai566);
if(status != OK){
logMsg("%s: failed to map XY566 A16 base addr A16=%x\n",
__FILE__,
base_addr);
return ERROR;
/* map the io card into the standard address space */
status = sysBusToLocalAdrs(VME_AM_STD_SUP_DATA,paimem, &pai566io);
if(status != OK){
logMsg( "%s: failed to map XY566 A24 base addr A24=%x\n",
__FILE__,
paimem);
return ERROR;
Hope this helps,
Bob
- XVME 566 driver problem Miroslaw Dach
Re: Power PC and EPICS Noboru Yamamoto
<1998>
Histogram Record support Mark J. Ryan
<1998>
