1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: New 167
To: [email protected]
Date: Mon, 20 Jul 1998 15:48:03 -0500
> >> I just pulled my brand new MVME167 from its box, plugged in the
> >> ROMs which had been in a known-good CPU and plugged it into my test
> >> ioc. It echos the boot params and tells me it's attaching
> >> interfaces, as usual. Then it says "Loading..." for several minutes
> >> and eventually fails. The known-good CPU continues to work fine
> >> (when I swapped everything back). Is there something with the ROM
> >> version that won't work on this new CPU, is the CPU bad, or am I
> >> just missing something (as usual)?
> >> Thanks for the help.
> >> -- Garrett Rinehart
> >>    IPNS, ANL
> >Perhaps you need to purge the "arp" cache on the boot host
> >when changing the Ethernet address which corresponds to a particular
> >IP address. Type "man arp" for the details.
> I got bit on exactly this same problem a week or two back, and that was the
> cure -
> wait for the table to time out.  I think it requires root privelege (at
> least on
> our systems) to force a purge.
Thank you, Jeff and Bill. Now that you mention it, I remember
reading those notes about the ARP stuff. Sorry I didn't recall
that before bothering everyone again.
-- Garrett
Prev: RE: New 167 Bill Brown
Next: gdct313 & solaris 2.6 Hammonds, John
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
