1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: medm: leading zeros
To: Ned Arnold <[email protected]>
Cc: [email protected], [email protected]
Date: Tue, 23 Jun 1998 08:25:53 +0200
Ned Arnold wrote:
> > Is there a way to specify (in the record's PRECision field) to direct a medm
> > text monitor to fill the displayed VALue with leading zeros?  I want the
> > display to show '02',  not '2'.   In a printf statement the syntax would be
> > %02d.
> > -ps
> No, not directly. If its REAL important you could write a simple device
> support routine for a stringin record that puts it into whatever format
> you want. The stringin record could fetch the value you want using the
> .INP field.
>         Ned
There was a discussion at the SOSH 98 workshop at SLS resulting
in an agreement to standardize on a thing called "format" which
would be the same as a printf string for a single number. The context
was in device oriented API's, where access is to a named device with
a named property (deviceName + property == channel). Properties
then have "characteristics" like units, resolution, etc., and one of these
characteristics would be "format".
I don't yet know how we'll put this into CDEV and how we would then
map it to EPICS, but one possibility would be a new string field or
special method in the IOC. An alternate approach (for CDEV) would be
to  keep this information in a host resident database (transparent to
applications such as MEDM running on CDEV). This second approach
has already been demonstrated with CDEV by a group at CERN (and
perhaps also at BNL, I can't remember).
Chip
Re: medm: leading zeros Ned Arnold
Prev: Re: medm: leading zeros Tim Mooney
Next: Base R3.13.0beta12 for WIN32 from ANL Bakul Banerjee
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: medm: leading zeros Ned Arnold
Next: Re: medm: leading zeros Tim Mooney
