After reading back through the code - it seems to me that the Xy566
waveform is set up to use an external trigger for each sample. This
was accomplished with an 085 board that was designed at LANL (as I
recall). To use the 566 as an array you would need to:
1) 566 short address space to 9000
2) 566 standard IO space to 80000
3) remove the need for an 085
(Number 3 may be as easy as removing the need in the xy566_init routine
or may require setting something different in the init sequence so that
instead of an external trigger for each value - it uses only one trigger
to reset it - I could look into this further at a later time.)
Bob
- Xycom 566 waveform Garrett D. Rinehart
base release baseR3.13.0.beta12 Marty Kraimer
medm: leading zeros Paul Sichta
<1998>
Looking for BLT1.7 Brian McAllister
<1998>
