1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: more details - Re: boot problems & related on hkbaja47
To: [email protected]
Date: Wed, 17 Jun 1998 12:12:13 -1000
Ned Arnold wrote:
> The first time I had to log out/in of
> my Unix workstation before connections could be re-established, the next time
> that didn't work, I had to reboot my Unix workstation! It seems that
> something (caRepeater ?) does not like the CPU architecture to change from
> one boot of an IP number to another. I was going to send a note to Jeff, but
> now he's heard it. Jeff, I can reproduce this problem if you want to look at it.
Following Ned Arnold's advice I took the "I'll only want to do this
once" approach and rebooted my workstation. Unfortunately that didn't
help. Then I followed the rest of Rozelle's "Debugging EPICS ..."
paper and found:
My netmasks are ok.
The cpu is not busy.
"casr" says no clients are connected.
I can't find any of my channels with cau.
I thought I found it when I walked over to the (physical) console
and found that it said that the database initialization failed
(and below that said that the database initialization completed),
but then remembered that it always does that (no idea why).
(I also took out the changes I made to the database and that didn't
have any effect either).
Any suggestions welcome (I'm absolutely out of ideas).
Thanks again and in advance,
Maren
Problem solved ... Re: boot problems & related on hkbaja47 Maren Purves
Re: boot problems & related on hkbaja47 Ned Arnold
Prev: Re: boot problems & related on hkbaja47 Ned Arnold
Next: RE: boot problems & related on hkbaja47 Jeff Hill
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Problem solved ... Re: boot problems & related on hkbaja47 Maren Purves
