1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: boot problems & related on hkbaja47
To: [email protected], [email protected]
Date: Wed, 17 Jun 1998 12:56:36 -0600
Hi Maren,
The first question to ask when the dm screens won't connect is:
Is the net mask on your ioc set to the same as the
netmask on your sun?
In the boot parameters the line
inet on ethernet (e) : 128.165.32.88:ffffff00
Should look something like the above.
The ffffff00 after the : tell
the ioc to accept broadcasts from inet addresses in the 128.165.32....
subnet.
Of course there are lots of other possible problems:
(a run away sequence at higher priority than channel access will
do it), but I would look at the netmask first.
Good Luck,
Rozelle
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs LANSCE-8  FAX (505) 665-5107      |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
> From [email protected] Wed Jun 17 12:50 MDT 1998
> Sender: [email protected]
> Date: Wed, 17 Jun 1998 08:49:50 -1000
> Organization: Joint Astronomy Centre, Hilo, HI
> X-Mailer: Mozilla 3.01Gold (X11; I; SunOS 5.5 sun4m)
> Mime-Version: 1.0
> Subject: boot problems & related on hkbaja47
> Content-Transfer-Encoding: 7bit
> X-Lines: 32
> Hi all,
> after spending a day on it yesterday I guess it is time to ask:
> After having changed architecture from hkbaja60 to hkbaja47
> and IOC (crate) I ran into the following problems:
> - the hkbaja47 is only able to boot (load vxWorks) with one user id.
> I can't find any protection problems. It is not dependent on the host it
> boots from (at least).
> - after getting it to boot, I find that, while everything in the
> startup file appears to get executed ok, and checking with dbpr that
> the records actually process, my dm screen tells me that all the
> channels are disconnected. caRepeater is running, I took all access
> restrictions out of the resource.def file (and actually switched to
> doing the iocInit without file specification)
> - when I run Crosswind it still believes that I have the old hkbaja60
> architecture and says it can't read the files.
> System details:
> Epics 3.13 beta 11, Tornado 1.0.1 (hkbaja47),
> Solaris 2.6 (sparc 20 clone)
> I don't really need to run Crosswind, I just tried to run it to
> possible help me find what the rest of the problems are but instead
> found that there was problems with it too.
> Does anybody have any ideas what I'm overlooking?
> Thanks in advance,
> Maren Purves
> UKIRT
Re: boot problems & related on hkbaja47 Maren Purves
Prev: boot problems & related on hkbaja47 Maren Purves
Next: Re: boot problems & related on hkbaja47 Maren Purves
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
