1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Process-Valve icon color
To: [email protected], [email protected]
Date: Fri, 5 Jun 1998 17:21:18 +0200 (METDST)
> 2)  What color convention are you using ?
As BESSY is an accelerator facility, the valves that are monitored separate
different sections of the vacuum chamber. Closed valves block the beam, so
they are displayed red.
Generally our status color convention is that everything that may prevent the
machine from being fully operational is red, while normal operation status
is green.
[This even includes the radiation safety interlocks: So the "access" status
which is safe for humans to access the ring is red (with the machine being
forced off) and the "no access" status is green.]
Ralph
Process-Valve icon color Paul Sichta
Prev: Process-Valve icon color Paul Sichta
Next: BITBUS availability... Udo BOTHNER
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Process-Valve icon color Matthias Clausen DESY -MKS-2/KRYK-
