1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: OMS steppermotor problem
To: [email protected]
Date: Fri, 22 May 1998 14:55:32 -0500
A distribution of the Hideos source files that contain the fixes Mark
mentioned are available from the Hideos distribution web page. Look for
it under the "HiDEOS Source" section on
www.aps.anl.gov/asd/controls/hideos.
These fixes are only compatible with the Hideos version distributed from
May 97.
Even with these fixes we have still been able to crash Hideos under very
heavy simulated traffic. This is one of the reasons Marty Kraimer took
up the effort to port the Hideos drivers to VxWorks.
Mark Rivers wrote:
> Joe Sullivan found that the problem was that OMS interrupts which were
> supposed to be masked off were occasionally getting "unmasked" and occuring
> anyways.  My recollection is that his solution was to "remask" these
> interrupts in the interrupt service routine each time it was called.  This has
> completely fixed the problem.  It is not clear if this is an OMS hardware
> problem, a Hideos software problem, or software problem in the OMS driver.
> There have been a number of bugs found and fixed in Hideos recently, so the
> "kluge" fix to the OMS driver may no longer be necessary.
Joe Sullivan
RE: OMS steppermotor problem Mark Rivers
Prev: Re: Advice sought on fanning data to several PVs Tim Mooney
Next: Visual SNL Steve Hunt
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: OMS steppermotor problem Mark Rivers
