1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: FYI...
To: [email protected]
Date: Fri, 10 Apr 1998 10:15:17 EDT
--- Begin Message ---
For anyone who hasn't yet built EPICS on Linux 5.0, I found the problem
with many of the error messages I reported when trying to build the
extensions, a few days ago. The answer was in the glibc FAQ (Thanks to
my supervisor for directing me to it):
"_GNU_SOURCE:  glibc does not make the GNU extensions available
automatically.  If a program depends on the GNU extensions or some other
non-standard functionality, it is necessary to compile it with the C
compiler option -D_GNU_SOURCE, or better to put #define _GNU_SOURCE at
the beginning of your source files, before any C library header files
are included.  This difference normally manifests itself in the form
of missing prototypes and/or data type definitions.  Thus, if you get
such errors, the first thing you should do is try defining _GNU_SOURCE
and see if that makes the problem go away."
In most cases, it does.
Many of you who have been working with Linux a long time, probably  knew
this, but for those whose experience is as limited as mine, I figured
I'd post this, and maybe it will help someone.
Bonnie Madre
Accelerator Development
Integration and Assessment Group
ANALOG ADDRESS:
Thomas Jefferson National Accelerator Facility (TJNAF)
MS 58
12000 Jefferson Avenue
Newport News, VA  23606
(757) 269-7059
E-MAIL ADDRESS:
[email protected]
--- End Message ---
Prev: [no subject] David Hon
Next: RE: Jeff Hill
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Jeff Hill
