I don't know if Metrolink's Motif has it but I know that Red Hat's does.
We do have MEDM and stripTool compiled on Linux.
John
> -----Original Message-----
> From: [email protected]
> [SMTP:[email protected]]
> Sent: Wednesday, April 01, 1998 10:33 AM
> To: [email protected]
> Cc: [email protected]
> Subject: Re: CA Server and EPICS
> On Tue, 31 Mar 1998, John Sinclair wrote:
> > On Tue, 31 Mar 1998, Dan Yocum wrote:
> > > John,
> > > How did the build go under RH5.0? Did you get the extensions
> built as well?
> > > Do you have any notes that might be useful?
> > > For some reason, I can't get the extensions built on my RH4.2
> system and am
> > > going to try to build the whole thing on a 5.0 to see if I have
> any luck.
> > The build of base went fine. I have not yet tried to build
> extensions.
> > I need to install motif first.
> One thing you should be aware of before you buy Motif is that the
> newest
> releases of Metrolink Motif for Linux include an unsupported, but free
> copy of the Xrt packages like XrtGraph. This means you only have to
> spend
> about $200 to get XrtGraph on Linux rather than the several thousands
> of
> dollars you have to spend to get it on other platforms.
> I have built Medm version 2.3.3 for EPICS 3.13.0 beta 11 under Debian
> Linux 1.3.1 and had very little problem getting it to work. There was
> only one line in the Medm source that I had to patch, namely:
> *** src/medm/medm/medmComposite.c.orig Thu Nov 6 12:58:08 1997
> --- src/medm/medm/medmComposite.c Fri Jan 9 18:34:16 1998
> *** 193,201 ****
> --- 193,208 ----
> clearResourcePaletteEntries();
> unhighlightSelectedElements();
> clearDlDisplayList(cdi->selectedDlElementList);
> + #if defined(linux)
> + /* WML */
> + if (!(elementPtr = createDlElement(0,NULL,NULL))) {
> + return 0;
> + #else
> if (!(elementPtr = createDlElement(NULL,NULL,NULL))) {
> return 0;
> + #endif
> elementPtr->structure.element = dlElement;
> appendDlElement(cdi->selectedDlElementList,elementPtr);
> The first parameter for createDlElement() is an enum type and GCC
> under Linux gets upset if you pass a NULL to it. However, if you
> pass it a zero, GCC is happy.
> MRCAT at the Advanced Photon Source has been using Medm under Linux
> for about two months now and almost everything we've tested seems to
> work correctly. The only minor anomaly I've seen is that if you click
> on the right mouse button to pop up the little menu that says "Print",
> "Close", etc., the Medm display that you clicked on jumps to the top
> of the stack of windows and hides the popup menu. This is only a
> minor nuisance as long as you remember to move your mouse to the far
> right hand side of the Medm display before clicking the right mouse
> button. Then, most of the popup menu is outside the boundary of the
> main Medm window and isn't hidden anymore. This behavior happens
> under
> both the FVWM window manager and the FVWM95 window manager.
> One final comment is that you should be sure to use the newest version
> of the Medm source, namely, version 2.3.3. If you run older versions
> of Medm under the FVWM or FVWM95 window managers, they die with an
> error message like:
> X Error of failed request: BadAccess (attempt to access private
> resource denied)
> Major opcode of failed request: 28 (X_GrabButton)
> Serial number of failed request: 1336
> Current serial number in output stream: 1338
> But Medm 2.3.3 runs under the FVWM family of window managers just
> fine.
> Bill Lavender
> Illinois Institute of Technology/IMCA-CAT/MRCAT
> [email protected]
> Phone: +1-630-252-0523, Fax: +1-630-252-0521
Re: CA Server and EPICS Bill Lavender
Re: EPICS and WindRiver's Tornado Maren Purves
<1998>
EPICS and WindRiver's Tornado Rosemary Alles
<1998>
