1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CA Server
To: "Hammonds, John" <[email protected]>
Cc: tech talk <[email protected]>
Date: Wed, 1 Apr 1998 08:40:25 -0500 (EST)
John,
I guess I was assuming that you and Jeff set EPICS_CA_ADDR_LIST on
the local node to be 127.0.0.1 and then you could run ca_test on the
same node as the server. I did do this to confirm that I was understanding
what was happening in the code and then things would work with both
pieces on the same node. Setting EPICS_CAS_INTF_ADDR_LIST, however, makes
things work both on the local node and on a remote node (at least for
my environment). There is apparently another problem running with your
version of Linux.
John Sinclair
[email protected]
Oak Ridge National Lab
423-576-6362
423-574-1268 (fax)
On Tue, 31 Mar 1998, Hammonds, John wrote:
> John,
> Do you consider this a total fix?  I tested this out and it does work as
> long as excas is run on the same node that you do the ca_test from.  I
> set up to test this and if I run both of these on the same machine I get
> good results.  If I run ca_test (or some other ca utility) on another
> machine, I get a message that fred was not found.  This seems similar to
> the problem that I had when looking over this with Jeff Hill.  I even
> think that this may have been the same variable that we set to get it to
> work through localhost.
RE: CA Server Hammonds, John
Prev: help ? SNL hangs, EDD/DM 'byte' widget bugs Matthieu Bec
Next: Re: EPICS and WindRiver's Tornado Marty Kraimer
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: CA Server Hammonds, John
Next: Re: CA Server Steve Lewis
