1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
To: [email protected], [email protected]
Date: Fri, 20 Mar 1998 07:51:15 -0700
Hi Yujong Kim,
1.  The cc68k compiler is getting the wrong version of as.
I had a similar problem when trying to build Epics under Tornado.
Janet Anderson
suggested making a link in the tornado distribution.
(Our tornado is installed at /usr/local/vx/T101).
First cd to
/usr/local/vx/T101/host/sun4-solaris2/lib/gcc-lib/m68k-wrs-vxworks/cygnus-2.7.2-960126
Then
ln -s /usr/local/vx/T101/host/sun4-solaris2/m68k-wrs-vxworks/bin/as as
This works, but I don't thing it is  a really satisfactory solution.
In the newest copy of epics which I just checked out, I can get by without
the link if I have
WIND_BASE
and
WIND_HOST_TYPE
environmental variables set properly, but that doesn't seem to help in
the beta11 release.
2.  You also need two extra compiler flags to get rid of the warnings
about memcpy
These flags will be included in the next release of epics.
-fstrength-reduce -fno-builtin
3.  I notice you sent your message as root.
If you installed epics as root,  ordinary users may have problems using it.
Rozelle Wright
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs LANSCE-8  FAX (505) 665-5107      |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
> From [email protected] Thu Mar 19 19:51 MST 1998
> Date: Fri, 20 Mar 1998 11:49:49 +0900 (KST)
> Apparently-To: <[email protected]>
> Content-Type: text
> Content-Length: 23619
> X-Lines: 804
> Dear Sir
> I am a graduate student of POSTECH in Korea.
> ( POSTECH and POSCO built Pohang Accelerator Laboratory [PAL] )
> I must install EPICS in my machine to develope the longitudinal feedback system.
> But I can't install EPICS in my machine. Some errors happened.
> My machine is SUN Enterprise Server 450.
> OS is Solaris2.6
> VxWorks is the Tornado-1.0.1 which is located at /usr/local/tornado-1.0.1
> EPICS  is the EPICS-3.13.0.b11 which is located at /usr/local/epics
> GCC for HOST (Solaris) is  gcc-2.7.2.3 which is located /usr/local/gcc-2.7.2.3
> GCC for sun3 is gcc-2.7.2.3 wihich is localted at /usr/local/hideos/gnu/gcc-2.7.2.3
> GCC BIN for HOST is located at /usr/local/bin
> GCC BIN for sun3 is located at /usr/local/hideos/gnu/bin
> GCC BIN for Vx-Works (i.e cc68k, as68k etc...) is located
> 	at /usr/local/tornado-1.0.1/host/sun4-solaris2/bin
> Sun Compiler is located /opt/SUNWspro/
> I must compile EPICS for the target boards which are the mv162 and mv166.
> first, I Compiled EPICS for HOST :
> After editing  /usr/local/epics/base/config/CONFIG, CONFIG.SITE, CONFIG.solaris
> 		CONFIG.mv162, CONFIG_SITE.solaris, CONFIG.Vx.68k, CONFIG_COMMON
> 		,CONFIG_BASE.
> Question[1] : Are they the right files to edit ?
> 	after editing such files;
> 	make clean
> 	make depends.solaris
> 	make solaris
> 	make install.solaris
> 	in order to install EPICS for HOST
> Question[2] : Are they the right processes ?
> and Installation for HOST had no any error.
> So I tried to install mv162.
> 	make depends.mv162
> 	make mv162
> But in making mv162, Some errors happened:
> Question[3] do you know why those errors happened ?
> ------ Error Messages in making mv162 ----------------------------
> make[2]: Entering directory `/usr/local/epics-3.13.0.b11/base/src/libCom'
> make -C O.mv162 -f ../Makefile.Vx T_A=mv162
> make[3]: Entering directory `/usr/local/epics-3.13.0.b11/base/src/libCom/O.mv162'
> rm -f calcPerform.o
> /usr/local/tornado-1.0.1/host/sun4-solaris2/bin/cc68k -B/usr/local/tornado-1.0.1/host/sun4-solaris2/lib/gcc-lib/ -nostdinc   -DCPU=MC68040 -m68040 -DCPU_FAMILY=MC680X0 -O -Wall -pedantic -ansi -I. -I.. -I../../../src/include/os/vxWorks -I../../../include -I../../../include -I../../../include/os/vxWorks -I/usr/local/tornado-1.0.1/target/h -DvxWorks -DV5_vxWorks   -c ../calcPerform.c
> In file included from ../calcPerform.c:109:
> /usr/local/tornado-1.0.1/target/h/string.h:39: warning: conflicting types for built-in function `memcmp'
> /usr/local/tornado-1.0.1/target/h/string.h:40: warning: conflicting types for built-in function `memcpy'
> as: unrecognized option `-m68040'
> make[3]: *** [calcPerform.o] Error 1
> make[3]: Leaving directory `/usr/local/epics-3.13.0.b11/base/src/libCom/O.mv162'
> make[2]: *** [mv162] Error 2
> make[2]: Leaving directory `/usr/local/epics-3.13.0.b11/base/src/libCom'
> make[1]: *** [libCom.mv162] Error 2
> make[1]: Leaving directory `/usr/local/epics-3.13.0.b11/base/src'
> make: *** [src.mv162] Error 2
> codia[146]#
> So I can't install EPICS anymore.
> If do you know the reason making errors. Please help me.
> My CONFIG files are:
> 1) /base/config/CONFIG
> #  $Id: CONFIG,v 1.11 1997/06/25 00:48:06 jhill Exp $
> #  The developer may edit this file.
> # assume T_A is the host arch if not specified
> ifndef T_A
> T_A = $(HOST_ARCH)
> endif
> #  EPICS base definitions
> include $(EPICS_BASE)/config/CONFIG_COMMON
> #  Site-specific build options
> include $(EPICS_BASE)/config/CONFIG_SITE
> #  Architecture specific definitions
> include $(EPICS_BASE)/config/CONFIG.$(T_A)
> -include $(EPICS_BASE)/config/CONFIG_SITE.$(T_A)
> #  User specific definitions
> -include $(HOME)/EPICS_CONFIG
> -include $(HOME)/EPICS_CONFIG.$(HOST_ARCH)
> #  All EPICS options other than BUILD_TYPE
> #   may be overridden here.
> # EXAMPLES
> #  Build client objects statically ?  must be either YES or NO
> #STATIC_BUILD=NO
> #  Unix Optimization,   must be either YES or NO
> #UNIX_OPT=YES
> #  VxWorks Optimization,  must be either YES or NO
> #VX_OPT=YES
> #  Generate Verbose Compiler Warnings for Unix,  must be either YES or NO
> #UNIX_WARN=YES
> #  Generate Verbose Compiler Warnings for VxWorks,  must be either YES or NO
> #VX_WARN=YES
> #etc.
> 2) /base/config/CONFIG.Vx.68k
> # $Id: CONFIG.Vx.68k,v 1.17 1997/05/05 17:56:58 jba Exp $
> # This file is maintained by the EPICS community.
> AR = $(VX_GNU_BIN)/ar68k
> RANLIB = $(VX_GNU_BIN)/ranlib68k
> YACC = $(EYACC)
> LEX = $(ELEX)
> CC = $(VX_GNU_BIN)/cc68k -B$(VX_GNU_LIB)/gcc-lib/ -nostdinc
> CPP = $(VX_GNU_BIN)/cpp68k -nostdinc
> #CPP = $(CC) -E
> GCC = $(CC)
> LD = $(VX_GNU_BIN)/ld68k -r
> EPICS_LDLIBS =
> MV=mv
> RM=rm -f
> MKDIR = mkdir
> RMDIR=rm -rf
> WHAT = what
> # Only G++ currently supported
> CPLUSPLUS = G++
> CXXCMPLR = NORMAL
> VX_OPT = YES
> BOARD = $(subst mv,MV,$(T_A))
> CPU = 68000
> OS = VXWORKS
> CCC = $(VX_GNU_BIN)/cc68k -B$(VX_GNU_LIB)/gcc-lib/ -nostdinc
> AR_CCC = $(VX_GNU_BIN)/ar68k
> CPP_CCC = $(VX_GNU_BIN)/cpp68k -nostdinc
> RANLIB_CCC = $(VX_GNU_BIN)/ranlib68k
> LD_CCC = $(VX_GNU_BIN)/ld68k
> CCC_CCFLAGS =
> CCC_ARCH_DEP_CCFLAGS =
> CCC_ARCH_DEP_LDFLAGS =
> G++ = $(GNU_BIN)/sun3-g++ -B$(GNU_LIB)/gcc-lib/ -nostdinc -DEXPL_TEMPL
> AR_G++ = $(GNU_BIN)/sun3-ar
> CPP_G++ = $(GNU_BIN)/sun3-c++
> RANLIB_G++ = $(GNU_BIN)/sun3-ranlib
> LD_G++ = $(GNU_BIN)/sun3-ld
> G++_ARCH_DEP_CCFLAGS = --no-builtin -Wa,"-m68040" -DOS_EQ_$(OS) \
> 	-DBOARD_EQ_$(BOARD) -DCPU_EQ_$(CPU) -DBOARD=$(BOARD)
> G++_ARCH_DEP_LDFLAGS = -Ur -N -T$(EPICS_BASE_BIN)/vxldscript.MRI
> CCC_NORMAL = $(CCC)
> CCC_STRICT = $(CCC) -ansi -pedantic -Wtraditional \
>       -Wmissing-prototypes -Woverloaded-virtual \
>       -Wwrite-strings -Wconversion -Wstrict-prototypes\
>       -Wpointer-arith -Winline
> G++_NORMAL = $(G++)
> G++_STRICT = $(G++) -ansi -pedantic -Wtraditional
> CXX = $($(CPLUSPLUS)_$(CXXCMPLR))
> AR_CXX = $(AR_$(CPLUSPLUS))
> CPP_CXX = $(CPP_$(CPLUSPLUS))
> RANLIB_CXX = $(RANLIB_$(CPLUSPLUS))
> LD_CXX = $(LD_$(CPLUSPLUS))
> ARCH_DEP_CXXFLAGS += $($(CPLUSPLUS)_ARCH_DEP_CCFLAGS) $(ARCH_DEP_CFLAGS)
> ARCH_DEP_CXXLDFLAGS =  $($(CPLUSPLUS)_ARCH_DEP_LDFLAGS) $(ARCH_DEP_LDFLAGS)
> # special c library requirements
> SPECIAL_LANG =
> # Compiler flags, don't mess with this
> #    Optimization flags
> VX_OPT_YES = -O
> VX_OPT_NO =
> VX_OPT_FLAGS = $(VX_OPT_$(VX_OPT))
> #    Include files
> VX_INCLUDES = -I. -I.. $(USR_INCLUDES) -I$(INSTALL_INCLUDE) -I$(EPICS_BASE_INCLUDE) \
> 	-I$(EPICS_BASE_INCLUDE)/os/vxWorks -I$(VX_INCLUDE)
> #    Warnings
> #At some time we should turn on pedantic
> VX_WARN_YES = -Wall -pedantic -ansi
> #VX_WARN_YES = -Wall
> VX_WARN_NO =
> VX_WARN_FLAGS = $(VX_WARN_$(VX_WARN))
> #    Operating system flags
> VX_OP_SYS_FLAGS = -DvxWorks -DV5_vxWorks
> #    Arch dependent flags are set in CONFIG_ARCH.*
> VX_CFLAGS = $(VX_OPT_FLAGS) $(VX_WARN_FLAGS) \
>         $(VX_INCLUDES) $(VX_OP_SYS_FLAGS)
> VX_CXXFLAGS += $(VX_CFLAGS)
> TARGET_CFLAGS = $($(basename $@)_CFLAGS)
> TARGET_CXXFLAGS = $($(basename $@)_CXXFLAGS)
> TARGET_LDFLAGS = $($(basename $@)_LDFLAGS)
> TARGET_CPPFLAGS = $($(basename $@)_CPPFLAGS)
> TARGET_SNCFLAGS = $($(basename $@)_SNCFLAGS)
> CFLAGS = $(TARGET_CFLAGS) $(USR_CFLAGS) $(ARCH_DEP_CFLAGS) $(VX_CFLAGS)
> CXXFLAGS = $(TARGET_CXXFLAGS) $(USR_CXXFLAGS) $(ARCH_DEP_CXXFLAGS) $(VX_CXXFLAGS)
> LDFLAGS =    $(TARGET_LDFLAGS) $(USR_LDFLAGS) $(ARCH_DEP_LDFLAGS) $(VX_LDFLAGS)
> LDLIBS = $(TARGET_LDLIBS) $(USR_LDLIBS) $(ARCH_DEP_LDLIBS) $(VX_LDLIBS)
> CXXLDLIBS = $(TARGET_LDLIBS) $(USR_CXXLDLIBS) $(ARCH_DEP_LDLIBS) $(VX_LDLIBS)
> CXXLDFLAGS = $(TARGET_LDFLAGS) $(USR_CXXLDFLAGS) $(ARCH_DEP_CXXLDFLAGS) $(VX_LDFLAGS)
> CPPFLAGS += $(TARGET_CPPFLAGS) $(USR_CPPFLAGS)
> # Build compile line here
> COMPILE.c = $(CC) $(CFLAGS) $(CPPFLAGS) -c
> LINK.c = $(LD) $(LDFLAGS) -o
> COMPILE.cc = $(CXX) $(CXXFLAGS) $(CPPFLAGS) -c
> LINK.cc = $(LD_CXX) $(CXXLDFLAGS) -o
> CPPSNCFLAGS = $(VX_INCLUDES)
> DEPENDS_RULE.c = -$(COMPILE.c) -M $(SRCS.c) >> .DEPENDS
> DEPENDS_RULE.cc = -$(COMPILE.cc) -M $(SRCS.cc) >> .DEPENDS
> # Allow site host architecture specific overrides
> -include $(EPICS_BASE)/config/CONFIG_SITE.$(BUILD_TYPE).$(ARCH_CLASS).$(HOST_ARCH)
> 3) /base/config/CONFIG.mv162
> # $Id: CONFIG.mv162,v 1.1 1996/07/11 19:16:25 jba Exp $
> # BUILD_TYPE
> BUILD_TYPE = Vx
> # For Vx directories of form:
> #   $(VX_DIR)/$(HOST_ARCH).$(ARCH_CLASS)/bin
> ARCH_CLASS = 68k
> include $(EPICS_BASE)/config/CONFIG.$(BUILD_TYPE).$(ARCH_CLASS)
> # Architecture specific build flags
> ARCH_DEP_CFLAGS = -DCPU=MC68040 -m68040 -DCPU_FAMILY=MC680X0
> 4) /base/config/CONFIG.solaris
> # $Id: CONFIG.solaris,v 1.14 1997/04/23 16:55:23 jhill Exp $
> # BUILD_TYPE
> #   Currently either Vx or Host
> BUILD_TYPE = Host
> ARCH_CLASS = solaris
> # Compiler and utility invocation (supply path to compiler here)
> #   (with warning flags built in)
> #  Paths to compilers
> GCC = /usr/local/bin/gcc
> ACC = $(SPARCWORKS)/bin/cc
> # SUNCC doesn't exist under Solaris
> # required by sun's C++ compiler
> AR = ar
> _AR = $(AR) $(ARFLAGS)
> G++_AR = $(_AR)
> CCC_AR = $(CCC) -xar -o
> ARCMD = $($(CPLUSPLUS)_AR)
> RANLIB =
> YACC = $(EYACC)
> LEX = $(ELEX)
> G++ = /usr/local/bin/g++
> CCC = /opt/SUNWspro/bin/CC
> CP=cp
> MV=mv
> RM=rm -f
> MKDIR=mkdir
> RMDIR=rm -rf
> CHMOD = "/bin/chmod"
> WHAT = what
> EXE=
> OBJ=.o
> ACC_ANSI_INVOKE_W_NO = $(ACC) -Xa -w
> ACC_ANSI_INVOKE_W_YES = $(ACC) -Xa
> ACC_STRICT_INVOKE_W_YES = $(ACC) -Xc -v
> ACC_TRAD_INVOKE_W_NO = $(ACC) -Xs -w
> ACC_TRAD_INVOKE_W_YES = $(ACC) -Xs
> ACC_LD_FLAGS =
> ACC_LD_LIBS =
> SUNCC_TRAD_INVOKE_W_NO = $(ACC_TRAD_INVOKE_W_NO)
> SUNCC_TRAD_INVOKE_W_YES = $(ACC_TRAD_INVOKE_W_YES)
> GCC_ANSI_INVOKE_W_NO = $(GCC) -ansi -w
> GCC_ANSI_INVOKE_W_YES = $(GCC) -ansi
> GCC_STRICT_INVOKE_W_YES = $(GCC) -ansi -Wall -pedantic
> GCC_TRAD_INVOKE_W_NO = $(GCC) -traditional -w
> GCC_TRAD_INVOKE_W_YES = $(GCC) -traditional
> GCC_LD_LIBS =
> GCC_LD_FLAGS =
> C_OLD = $($(STANDARD)_TRAD_INVOKE_W_$(UNIX_WARN))
> C_ANSI = $($(ANSI)_ANSI_INVOKE_W_$(UNIX_WARN))
> C_STRICT = $($(ANSI)_STRICT_INVOKE_W_YES)
> CC = $(C_$(CMPLR))
> LD_LIBS_OLD = $($(STANDARD)_LD_LIBS)
> LD_LIBS_ANSI = $($(ANSI)_LD_LIBS)
> LD_LIBS_STRICT = $($(ANSI)_LD_LIBS)
> CCOMPILER_LDLIBS = $(LD_LIBS_$(CMPLR))
> LD_FLAGS_OLD = $($(STANDARD)_LD_FLAGS)
> LD_FLAGS_ANSI = $($(ANSI)_LD_FLAGS)
> LD_FLAGS_STRICT = $($(ANSI)_LD_FLAGS)
> CCOMPILER_LDFLAGS = $(LD_FLAGS_$(CMPLR))
> CCC_NORMAL_INVOKE_W_NO = $(CCC) +p
> CCC_NORMAL_INVOKE_W_YES = $(CCC) +p +w
> CCC_STRICT_INVOKE_W_YES = $(CCC) +p +w
> CCC_LD_FLAGS = -L$(SPECIAL_LANG)
> CCC_LD_LIBS =
> CCC_TEMPL_INST_FLAG =
> G++_NORMAL_INVOKE_W_NO = $(G++) -ansi -pedantic -w
> G++_NORMAL_INVOKE_W_YES = $(G++) -ansi -pedantic -Wall
> G++_STRICT_INVOKE_W_YES = $(G++) -ansi -pedantic -Wtraditional -Wall \
> G++_TEMPL_INST_FLAG = -DEXPL_TEMPL
> CXX_NORMAL = $($(CPLUSPLUS)_NORMAL_INVOKE_W_$(UNIX_WARN))
> CXX_STRICT = $($(CPLUSPLUS)_STRICT_INVOKE_W_YES)
> TEMPL_INST_CXXFLAG = $($(CPLUSPLUS)_TEMPL_INST_FLAG)
> # GNU make likes CXX instead of CCC
> CXX = $(CXX_$(CXXCMPLR))
> # Static Build options
> #ACC_SFLAGS_YES= -dn
> ACC_SFLAGS_YES= -Bstatic
> ACC_SLIBS_YES= -lw -lintl -Bdynamic -ldl -Bstatic -lXext -lX
> ACC_SLIBS_NO=
> ACC_SFLAGS_NO=
> CC_SFLAGS_YES= -dn
> CC_SFLAGS_NO=
> GCC_SFLAGS_YES= -static
> GCC_SFLAGS_NO=
> SF_OLD = $($(STANDARD)_SFLAGS_$(STATIC_BUILD))
> SF_ANSI = $($(ANSI)_SFLAGS_$(STATIC_BUILD))
> SF_STRICT = $(SF_ANSI)
> UNIX_SFLAGS = $(SF_$(CMPLR))
> SL_OLD = $($(STANDARD)_SLIBS_$(STATIC_BUILD))
> SL_ANSI = $($(ANSI)_SLIBS_$(STATIC_BUILD))
> SL_STRICT = $(SL_ANSI)
> UNIX_SLIBS = $(SL_$(CMPLR))
> # Optimization
> OPTIM_YES = -O
> OPTIM_NO =
> UNIX_OPT_FLAGS = $(OPTIM_$(UNIX_OPT))
> # Include files
> UNIX_INCLUDES = -I. -I.. $(USR_INCLUDES) -I$(INSTALL_INCLUDE) -I$(EPICS_BASE_INCLUDE) \
>                 -I$(EPICS_BASE_INCLUDE)/os/$(T_A)
> OP_SYS_FLAGS = -DUNIX
> UNIX_LDFLAGS = -L$(EPICS_BASE_LIB) $(CCOMPILER_LDFLAGS)
> UNIX_LDLIBS = $(UNIX_SLIBS) -lm $(CCOMPILER_LDLIBS)
> ARCH_DEP_CFLAGS = -DSOLARIS
> ARCH_DEP_CXXFLAGS = $(ARCH_DEP_CFLAGS)
> ARCH_DEP_LDLIBS = -lsocket -lnsl
> # -lsocket     needed by libca.a
> # -lnsl        needed by libca.a
> UNIX_CFLAGS = $(UNIX_SFLAGS) $(UNIX_INCLUDES) $(OP_SYS_FLAGS)
> UNIX_CXXFLAGS = $(UNIX_CFLAGS)
> # Target specific flags
> TARGET_LDLIBS = $($(basename $@)_LDLIBS)
> CFLAGS = $(UNIX_OPT_FLAGS) $(TARGET_CFLAGS) $(USR_CFLAGS) $(ARCH_DEP_CFLAGS) $(UNIX_CFLAGS)
> CXXFLAGS = $(UNIX_OPT_FLAGS) $(TARGET_CXXFLAGS) $(USR_CXXFLAGS) \
> 	$(ARCH_DEP_CXXFLAGS) $(UNIX_CXXFLAGS) $(TEMPL_INST_CXXFLAG)
> LDFLAGS = $(SPECIAL_LDFLAGS) $(TARGET_LDFLAGS) $(USR_LDFLAGS) $(ARCH_DEP_LDFLAGS) $(UNIX_LDFLAGS)
> LDLIBS = $(TARGET_LDLIBS) $(USR_LDLIBS) $(ARCH_DEP_LDLIBS) $(UNIX_LDLIBS)
> # Override SUN defaults
> # Unlike the 'Unix' makesystem, output flags -o .. are now part of LINK.c[c]
> LINK.c = $(CC) -o $@ $(CFLAGS) $(CPPFLAGS) $(LDFLAGS)
> LINK.cc = $(CXX) -o $@ $(CXXFLAGS) $(CPPFLAGS) $(LDFLAGS)
> DEPENDS_RULE.c = -$(COMPILE.c) -xM $(SRCS.c) > .DEPENDS
> DEPENDS_RULE.cc = -$(COMPILE.cc) -xM $(SRCS.cc) >> .DEPENDS
> 5) /base/config/CONFIG_BASE
> #  $Id: CONFIG_BASE,v 1.14 1997/06/25 06:40:24 jhill Exp $
> # the order of following list is important
> # for c++ build add the dirs gdd and cas after ca
> # (and uncomment the c++ files in src/lbCom/Makefile.Unix)
> DIRS = tools
> DIRS += include
> DIRS += cxxTemplates
> DIRS += toolsComm
> DIRS += libCom
> DIRS += libvxWorks
> DIRS += cvtDctsdr
> DIRS += dbStatic
> DIRS += db
> DIRS += bpt
> DIRS += ca
> DIRS += util
> DIRS += misc
> DIRS += sequencer
> DIRS += dbtools
> DIRS += rsrv
> DIRS += rec
> DIRS += as
> DIRS += drv
> DIRS += dev
> DIRS += devOpt
> DIRS += iocCore
> # if CPLUSPLUS isnt empty then include C++ src codes
> DIRS += $(patsubst %,gdd,$(strip $(CPLUSPLUS)))
> DIRS += $(patsubst %,cas,$(strip $(CPLUSPLUS)))
> EPICS_BASE = $(TOP)
> # EPICS include config file
> EPICS_BASE = $(INSTALL_LOCATION)
> # this speeds up the build by turning off implicit rules search
> # for EPICS Makefiles (which are not created from other files)
> .PHONY:: $(TOP)/config/CONFIG
> .PHONY:: $(TOP)/config/CONFIG.* $(TOP)/config/CONFIG_*
> .PHONY:: $(TOP)/config/RULES.* $(TOP)/config/RULES_* .DEPENDS
> .PHONY:: $(HOME)/EPICS_CONFIG $(HOME)/EPICS_CONFIG.$(HOST_ARCH)
> .PHONY:: ../Makefile.Vx ../Makefile.Unix ../Makefile.Host Makefile
> 6) /base/config/CONFIG_COMMON
> #  $Id: CONFIG_COMMON,v 1.9 1997/06/25 06:37:23 jhill Exp $
> #  CONFIG_COMMON - Another EPICS BASE config file
> #	by Matthew Needes and Mike Bordua
> #  This file is to be maintained by the EPICS community.
> # Common Configuration Information
> # CROSS1 will be defined only when CROSS_COMPILER_HOST_ARCHS is NOT defined
> CROSS1 = $(CROSS_COMPILER_TARGET_ARCHS$(word 1,$(CROSS_COMPILER_HOST_ARCHS)))
> # CROSS2 will be defined only when CROSS_COMPILER_HOST_ARCHS is defined
> # and HOST_ARCH is one of it's words
> CROSS2 = $(CROSS_COMPILER_TARGET_ARCHS$(filter-out 1,$(words $(filter $(HOST_ARCH),$(CROSS_COMPILER_HOST_ARCHS)))))
> BUILD_ARCHS = $(HOST_ARCH) $(CROSS1) $(CROSS2)
> INSTALL_LOCATION = $(TOP)
> INSTALL_LOCATION_LIB        = $(INSTALL_LOCATION)/lib
> INSTALL_LOCATION_BIN        = $(INSTALL_LOCATION)/bin
> INSTALL_INCLUDE             = $(INSTALL_LOCATION)/include
> INSTALL_DOC                 = $(INSTALL_LOCATION)/doc
> INSTALL_MAN                 = $(INSTALL_LOCATION)/man
> INSTALL_TEMPLATES           = $(INSTALL_LOCATION)/templates
> INSTALL_DBD                 = $(INSTALL_LOCATION)/dbd
> INSTALL_CONFIG              = $(INSTALL_LOCATION)/config
> EPICS_BASE_INCLUDE      = $(EPICS_BASE)/include
> EPICS_BASE_DBD          = $(EPICS_BASE)/dbd
> EPICS_EXTENSIONS_INCLUDE      = $(EPICS_EXTENSIONS)/include
> EPICS_EXTENSIONS_TEMPLATES    = $(EPICS_EXTENSIONS)/templates
> DIVIDER = .
> EPICS_BASE_HOST_BIN = $(EPICS_BASE)/bin/$(HOST_ARCH)
> # private versions of lex/yacc from EPICS
> EYACC = $(EPICS_BASE_HOST_BIN)/antelope$(EXE)
> ELEX = $(EPICS_BASE_HOST_BIN)/e_flex$(EXE) -S$(EPICS_BASE_INCLUDE)/flex.skel.static
> # Default for perl if it's on the PATH,
> # otherwise override this in e.g. CONFIG_SITE
> PERL=perl
> # install from EPICS
> INSTALL = $(PERL) $(EPICS_BASE_HOST_BIN)/installEpics.pl
> INSTALL_PRODUCT = $(INSTALL)
> # dbtools from EPICS
> # state notation language compiler (installed from base/src/sequencer)
> SNC = $(EPICS_BASE_HOST_BIN)/snc
> # vxWorks definitions
> VX_CONFIG_DIR = $(VX_DIR)/config
> VX_INCLUDE = $(VX_DIR)/h
> #VX_GNU_BIN = $(VX_GNU)/$(HOST_ARCH).$(ARCH_CLASS)/bin
> VX_GNU_BIN = /usr/local/tornado-1.0.1/host/sun4-solaris2/bin
> #VX_GNU_LIB = $(VX_GNU)/$(HOST_ARCH).$(ARCH_CLASS)/lib
> VX_GNU_LIB = /usr/local/tornado-1.0.1/host/sun4-solaris2/lib
> ifdef T_A
> INSTALL_LIB                 = $(INSTALL_LOCATION_LIB)/$(T_A)
> INSTALL_TCLLIB              = $(INSTALL_LOCATION_LIB)/$(T_A)
> INSTALL_BIN                 = $(INSTALL_LOCATION_BIN)/$(T_A)
> EPICS_BASE_LIB          = $(EPICS_BASE)/lib/$(T_A)
> EPICS_BASE_BIN          = $(EPICS_BASE)/bin/$(T_A)
> EPICS_EXTENSIONS_LIB          = $(EPICS_EXTENSIONS)/lib/$(T_A)
> EPICS_EXTENSIONS_BIN          = $(EPICS_EXTENSIONS)/bin/$(T_A)
> VX_IMAGE = $(VX_CONFIG_DIR)/$(T_A)/vxWorks
> VX_IMAGE_SYM = $(VX_CONFIG_DIR)/$(T_A)/vxWorks.sym
> # location of installed vxWorks image
> EPICS_VX_IMAGE = $(EPICS_BASE_BIN)/vxWorks
> EPICS_VX_IMAGE_SYM = $(EPICS_BASE_BIN)/vxWorks.sym
> endif
> 7) base/config/CONFIG_SITE
> #  $Id: CONFIG_SITE,v 1.12 1997/06/25 14:09:40 jba Exp $
> #  CONFIG_SITE  - EPICS BASE config file
> #  This file is to be modified by the EPICS system manager
> #	only.
> #  The host architecture performing the build,
> #	i.e.: the arch running DCT/getrel/etc.
> #  Currently Supporting:
> #	sun4
> #	hp700
> #	alpha
> #	solaris
> #	sgi
> #	Linux
> #	WIN32
> #  HOST_ARCH now an environment variable
> HOST_ARCH=$(shell /usr/local/epics/startup/HostArch)
> ifndef HOST_ARCH
> 	HOST_ARCH=unsupported
> endif
> #  The architectures to build EPICS for
> #       mv167
> #       mv162
> #       mv162lc
> #       mv147
> #       hkv2f
> #	niCpu030
> #	pc486
> #CROSS_COMPILER_TARGET_ARCHS=mv167
> CROSS_COMPILER_TARGET_ARCHS=mv162
> #  If only a subset of the host architectures perform
> #  the build for the CROSS_COMPILER_TARGET_ARCHS
> #  uncomment the following line and specify them.
> CROSS_COMPILER_HOST_ARCHS=solaris
> #  VxWorks directory
> #VX_DIR=$(VW)
> VX_DIR=/usr/local/tornado-1.0.1/target
> #  Gnu directory for gcc
> #VX_GNU = $(VX_GNU)
> VX_GNU = /usr/local/tornado-1.0.1/host/sun4-solaris2
> #  Gnu directory for g++
> #GNU_DIR = $(LOCAL_GNU)
> GNU_DIR = /usr/local/hideos/gnu
> GNU_BIN = $(GNU_DIR)/bin
> GNU_LIB = $(GNU_DIR)/lib
> #  Client ANSI Compiler
> #   GCC     (gcc -ansi)
> #   ACC     (acc)
> #   HPACC   (cc -Aa)
> #ANSI=HPACC
> ANSI=ACC
> #  Client Standard C Compiler choice
> #   GCC     (gcc -traditional)
> #   ACC     (acc -Xs)
> #   SUNCC   (cc)
> #   HPCC    (cc -Ac)
> #STANDARD=HPCC
> STANDARD=ACC
> #  C++ Compiler
> #   G++     (g++)   GNU C++
> #   CCC     (CC)    OS VENDOR C++
> #CPLUSPLUS=G++
> #Note: if CPLUSPLUS is empty then C++ src codes are not built
> #CPLUSPLUS=	# use this if site does not have C++ compiler
> CPLUSPLUS=CCC
> #        must be either YES or NO
> STATIC_BUILD=NO
> #  Unix Optimization
> UNIX_OPT=YES
> VX_OPT=YES
> UNIX_WARN=YES
> VX_WARN=YES
> # adl2dl
> ADL2DL = $(EPICS_EXTENSIONS)/bin/$(HOST_ARCH)/adl2dl
> # sch2edif compiler and flags
> SCH2EDIF = sch2edif
> SCH2EDIF_PATH =
> SCH2EDIF_SYSFLAGS = -n -ap -p.+..+$(SCH2EDIF_PATH)+$(EPICS_EXTENSIONS)/templates/capfast/sym+
> SCH2EDIF_FLAGS =
> # e2db and flags
> #    - again there is an assumption where edb.def is installed.
> E2DB = $(EPICS_EXTENSIONS)/bin/$(HOST_ARCH)/e2db
> E2DB_SYSFLAGS = -ate -d $(EPICS_EXTENSIONS)/templates/capfast/edb.def
> E2DB_FLAGS =
> 8) /base/config/CONFIG_SITE.solaris
> # $Id: CONFIG_SITE.solaris,v 1.3 1996/08/14 20:46:24 jba Exp $
> # Site Specific Configuration Information
> # Only the local epics system manager should modify this file
> # Default SUN compiler, individual Makefiles will override
> #  if they cannot support ANSI compilation.
> #   STRICT -  ANSI C - force warning flags
> #   ANSI   -  ANSI C
> #   OLD    -  Standard C - Not appropriate here.
> CMPLR=ANSI
> # Default SUN C++ compiler, individual Makefiles will override
> #  if they are coded to a higher standard.
> #   STRICT -  ANSI C++ force strict warning flags
> #   NORMAL -  ANSI C++ optional warning flags
> CXXCMPLR=NORMAL
> #CXXCMPLR=STRICT
> # Unbundled C compiler stuff
> SPARCWORKS = /opt/SUNWspro
> #SPECIAL_LANG = $(SPARCWORKS)/lib
> SPECIAL_LANG = .
> Question[4] Are settings of above files right ?
> Question[5] Where is the site(=URL) which I can obtain the information
>                           about installin of EPICS-3.13.0.b11 ?
> Question[6] In Compiling EPICS for mv162, must I make mv162 turn on ?
> 	    i.e) Solaris2.6 machine must communicate with mv162 target
> 		 through Tornado-1.0.1 in compiling EPICS for mv162 ?
> Question[7] I want to know how I can built mv166 target.
> 		Would you tell me the way ?
> Question[8] I want to know the right compiling processes  in making mv162 and
> 		mv166. Would you tell me the way  ?
> Question[9] I can't obtain documentations about compiling of EPICS-3.13.0.b11
>  	Every documentaions about EPICS installation are about old version EPICS	-3.12. Where can I obtain the new version install documentations ?
> Thank you for your help
> I hope to receive your answer soon r answer soon.
> from Yujong Kim
> [email protected]
> TEL/+82-562-279-1982
> FAX/+82-562-279-1699
> >From - Fri Mar 20 11:43:34 1998
> X-Mozilla-Status: 0001
> Message-ID: <[email protected]>
> Date: Fri, 20 Mar 1998 11:43:27 +0900
> From: System Administrator of Codia <[email protected]>
> Organization: POSTECH
> X-Mailer: Mozilla 3.04Gold (X11; I; SunOS 5.6 sun4u)
> MIME-Version: 1.0
> Subject: (no subject)
> Content-Type: text/plain; charset=euc-kr
> Content-Transfer-Encoding: 7bit
>   PAL Computational Server Codia System Administrator
>         Yujong Kim   [email protected]
>      TEL/ +82-562-279-1982 FAX/ +82-562-279-1699
Prev: Re: 3.13 Install question Ralph Lange
Next: Re: HADES openings at GSI Burkhard W. Kolb
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
