1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: record linking question
To: [email protected] (EPICS Tech-Talk)
Date: Tue, 17 Mar 1998 15:50:57 +0100 (MET)
> It is also possible to change any menu type via a DBR_STRING put.
> In this case the string value must exactly match one of the menu
> choices.
Depends on the CA client and how (if) it handles string values. If you use
the (host side) caput command (from extensions/src/ca) you will get:
> caput Q5PT1R:rdbk.SCAN ".5 second"
Old : Q5PT1R:rdbk.SCAN               .2 second
ca_put failed on Q5PT1R:rdbk.SCAN
> caput Q5PT1R:rdbk.SCAN 7
New : Q5PT1R:rdbk.SCAN               .5 second
Ralph
Re: record linking question Marty Kraimer
Prev: Re: record linking question Marty Kraimer
Next: Re: record linking question Ben-chin K. Cha
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
