1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Greenspring rs422 support
To: "Joseph P. Sullivan" <[email protected]>
Cc: <[email protected]>, <[email protected]>, <[email protected]>
Date: Wed, 11 Mar 1998 09:19:26 -0000
Joe,
	Thanks for the gory details... Looks like I'll have make to a few changes.
In regards to the Interrupt Routine - I ended up using the ISR masked with
the IMR to determine the transmit and receive conditions but still use the
SR to check for errors. So I suspect this is OK.
void tyGSOctalInt
<snip>
	block = i/2;
      chan = pTyGSOctalDv->chan;
      regs = pTyGSOctalDv->regs;
	sr = chan->u.r.sr;
	/* Only examine the active interrupts */
      isr = regs->u.r.isr & pQt->imr[block];
      /* Channel B interrupt data is on the upper nibble */
      if ((i%2) == 1) isr >>= 4;
      if (isr & SCC_ISR_RXRDY_A) /* a byte needs to be read */
	<snip RX logic>
	if (isr & SC_ISR_TXRDY_A) /* a byte needs to be sent */
      <snip TX Logic>
      if (sr & 0xf0)
	<snip ERROR logic>
>Second, interrupts were not being masked out when the IMR's TxRDY bit was
>set during the user's WRITE function. That left open a window when the
> UART's data structure did not match the state of the chip.
That's definitely a problem here.
> We also decided it was safer not to output the first character from
> the Write function.
Why is that? How do you start the transmit cycle? In my case this occurs in
the transmitter startup routine which is equivalent to the Write fucntion
in the HiDEOS driver.
Peregrine
Peregrine M. McGehee			Project Engineer: LEDA Control System
(505) 667-3273				[email protected]
LANSCE-8 Controls & Automation	Los Alamos National Laboratory
Re: Greenspring rs422 support Marty Kraimer
Prev: Re: SNC crashes William Lupton
Next: Re: Greenspring rs422 support Peregrine M. McGehee
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Greenspring rs422 support Joseph P. Sullivan
Next: Re: Greenspring rs422 support Marty Kraimer
