1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: what is the criterion for whether .VAL has PP attribute TRUE?
To: [email protected]
Date: Wed, 21 Jan 1998 13:56:44 +0100
Andy Foster wrote:
..SNIP
> The PP attribute being TRUE means that the record will be processed when
> that particular field is written to over Channel Access.
> Thus, it does not
> matter if the OUT link from another record is PP or NPP, the record at the
> far end of the link will process if the field being written to has it's PP
> attribute defined as TRUE and the link is over CA.
So, if I have a non-CA OUT link with PP set, and a target field that is
_not_ PP, the target record will still be processed? Or will it not be
processed?
	Ben
The Notorious Neb Nesknarf
BESSY II
Berliner Elektronenspeicherring-                phone: +49 30 6392-4865
Gesellschaft fuer Synchrotronstrahlung            fax: +49 30 6392-4859
Rudower Chaussee 5                         email: [email protected]
D-12489 Berlin                       web: http://www.bessy.de/~franksen
HOME: Benjamin Franksen, Fichtestr. 19a, D-10967 Berlin, +49(30)6913756
Re: what is the criterion for whether .VAL has PP attribute TRUE? Andy Foster
Prev: Re: what is the criterion for whether .VAL has PP attribute TRUE? Andy Foster
Next: Re: what is the criterion for whether .VAL has PP attribute TRUE? Andy Foster
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
