X-Sun-Data-Type: text
X-Sun-Data-Description: text
X-Sun-Data-Name: text
X-Sun-Charset: us-ascii
X-Sun-Content-Lines: 13
Dear all,
The sequencer problem that turned "i=0, j=0" into "i=0" has been fixed.
I attach a patch file relative to the R3.13.0Beta11 release. The fix will
(I assume) be present in the next Beta release.
If you don't want to patch your version of the sequencer, you can rest
assured that the above is the only circumstance under which the problem
occurred, and you can avoid it by re-coding to use multiple statements.
William
X-Sun-Data-Type: default
X-Sun-Data-Name: comma.patch
X-Sun-Content-Lines: 177
Index: r3.13/base/src/sequencer/gen_ss_code.c
diff -c r3.13/base/src/sequencer/gen_ss_code.c:1.1.1.1 r3.13/base/src/sequencer/gen_ss_code.c:1.3
*** r3.13/base/src/sequencer/gen_ss_code.c:1.1.1.1 Thu Oct 9 15:30:37 1997
--- r3.13/base/src/sequencer/gen_ss_code.c Tue Jan 13 15:48:33 1998
*** 10,15 ****
--- 10,16 ----
28apr92,ajk Implemented efClear() & efTestAndClear().
01mar94,ajk Changed table generation to the new structures defined
in seqCom.h.
+ 13jan98,wfl Fixed handling of compound expressions, using E_COMMA.
#include <stdio.h>
#include "parse.h"
*** 250,256 ****
int level; /* indentation level */
Expr *epf;
! int nparams;
extern int reent_opt;
extern int line_num;
--- 251,257 ----
Expr *epf;
! int nexprs;
*** 354,366 ****
if (special_func(stmt_type, ep, sp))
break;
printf("%s(", ep->value);
! for (epf = ep->left, nparams = 0; epf != 0; epf = epf->next, nparams++)
! if (nparams > 0)
printf(" ,");
eval_expr(stmt_type, epf, sp, 0);
- printf(") ");
break;
case E_ASGNOP:
case E_BINOP:
--- 355,370 ----
break;
! eval_expr(stmt_type, ep->left, sp, 0);
! printf(") ");
! break;
! case E_COMMA:
! for (epf = ep->left, nexprs = 0; epf != 0; epf = epf->next, nexprs++)
! if (nexprs > 0)
printf(" ,");
break;
case E_ASGNOP:
case E_BINOP:
*** 483,489 ****
case F_EFCLEAR:
case F_EFTESTANDCLEAR:
/* Event flag funtions */
! gen_ef_func(stmt_type, ep, sp, fname);
return TRUE;
case F_PVPUT:
--- 487,493 ----
case F_EFCLEAR:
! gen_ef_func(stmt_type, ep, sp, fname, func_code);
return TRUE;
case F_PVPUT:
*** 520,526 ****
* Note: name is changed by prepending "seq_". */
printf("seq_%s(ssId", fname);
/* now fill in user-supplied paramters */
! for (ep1 = ep->left; ep1 != 0; ep1 = ep1->next)
printf(", ");
eval_expr(stmt_type, ep1, sp, 0);
--- 524,533 ----
! ep1 = ep->left;
! if (ep1 != 0 && ep1->type == E_COMMA)
! ep1 = ep1->left;
! for (; ep1 != 0; ep1 = ep1->next)
printf(", ");
*** 547,552 ****
--- 554,561 ----
Chan *cp;
ep1 = ep->left; /* ptr to 1-st parameters */
+ if (ep1 != 0 && ep1->type == E_COMMA)
+ ep1 = ep1->left;
if ( (ep1 != 0) && (ep1->type == E_VAR) )
vp = (Var *)findVar(ep1->value);
else
*** 586,591 ****
--- 595,602 ----
int index;
ep1 = ep->left; /* ptr to 1-st parameter in the function */
+ ep1 = ep1->left;
if (ep1 == 0)
fprintf(stderr, "Line %d: ", ep->line_num);
Index: r3.13/base/src/sequencer/phase2.c
diff -c r3.13/base/src/sequencer/phase2.c:1.1.1.1 r3.13/base/src/sequencer/phase2.c:1.3
*** r3.13/base/src/sequencer/phase2.c:1.1.1.1 Thu Oct 9 15:30:37 1997
--- r3.13/base/src/sequencer/phase2.c Tue Jan 13 15:48:34 1998
*** 15,20 ****
--- 15,21 ----
01mar94,ajk Implemented new interface to sequencer (seqCom.h).
01mar94,ajk Implemented assignment of array elements to db channels.
01mar94,ajk Changed algorithm for assigning event bits.
+ 13jan98,wfl Supported E_COMMA token (for compound expressions).
/*#define DEBUG 1*/
*** 513,518 ****
--- 514,520 ----
case E_SS:
case E_STATE:
case E_FUNC:
+ case E_COMMA:
case E_CMPND:
case E_STMT:
case E_ELSE:
Index: r3.13/base/src/sequencer/snc.y
diff -c r3.13/base/src/sequencer/snc.y:1.1.1.1 r3.13/base/src/sequencer/snc.y:1.3
*** r3.13/base/src/sequencer/snc.y:1.1.1.1 Thu Oct 9 15:30:38 1997
--- r3.13/base/src/sequencer/snc.y Tue Jan 13 15:48:35 1998
*** 14,19 ****
--- 14,20 ----
31may94,ajk Changed method for handling global C code.
20jul95,ajk Added "unsigned" types (see UNSIGNED token).
11jul96,ajk Added character constants (CHAR_CONST).
+ 13jan98,wfl Added "down a level" handling of compound expressions
/* SNC - State Notation Compiler.
* The general structure of a state program is:
*** 246,252 ****
expr /* general expr: e.g. (-b+2*a/(c+d)) != 0 || (func1(x,y) < 5.0) */
/* Expr *expression(int type, char *value, Expr *left, Expr *right) */
! : compound_expr { $$ = $1; }
| expr binop expr %prec UOP { $$ = expression(E_BINOP, $2, $1, $3); }
| expr asgnop expr { $$ = expression(E_ASGNOP, $2, $1, $3); }
| unop expr %prec UOP { $$ = expression(E_UNOP, $1, $2, 0); }
--- 247,253 ----
! : compound_expr { $$ = expression(E_COMMA, "", $1, 0); }
new archiving capabilities for the frequency archiver Bob Dalesio
JOB-OFFER eckart
<1998>
JOB-OFFER eckart
<1998>
