g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
Subject: new archiving capabilities for the frequency archiver
To: tech-talk@aps.anl.gov
Date: Sat, 10 Jan 98 13:56:31 MST
Three significant changes have been made to the frequency archiver:
1) The frequency archiver is changed to support monitor capability as well -
it will be renamed the channel archiver to distinguish it from the save set archiver.
2) The disk allocation scheme has been modified to incrementally use more disk space
per file for a given channel. This will greatly reduce the amount of disk space used
when the channel is not changing frequently. It will add seeks on the data retrieval,
however, tests show that this is not going to impact retrieval speed more than 10%.
3) THe related information for a channel is now kept as well. This means that an
enumerated field being archived will also archive the strings that represent the
possible states. Analog type values will keep alarm limits, display limits, precision and
engineering units.
Prev: EPICS North American Meeting in April - to be held in Los Alamos Bob Dalesio
Next: sequencer problem with parsing "i=0, j=0" William Lupton
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
