> I think it would be a bad idea to set the record's version number in the .dbd
> file anyway. (It might not be so bad for the .dbd file to have its own version
> number, so record-support could verify that it wasn't compiled against an
> outdated header file.)
Since this can be checked at compile time, it should. There's no need to
have a runtime field for the dbd version in each record. If there was a
general way to include something in the database definition like
recordtype(record_type) {
define(TAG, "value")
which gets
#define record_typeRecordTAG value
in the header file, record support could easily check anything it wants to
at compile time or runtime.
> Anyway, I'm in favor of every record having a VERS field.
> I think the device support's version number should also be available via
> channel access.
If there are two different versions of one record or device support running
in parallel, their record type or DTYP must be different, so having a
version field would be redundant.
Is it really wanted two have different IOCs running different versions of
the same record or device support? (*Shudder*)
About a field or function getting the record type:
This would make it easier for multi-record-type device support functions to
efficiently retrieve the type of the record they are called by. [For the
time being I'm abusing the init_record() function called with NULL for
that.]
Ralph
- Re: EPICS r3.13 field DESC length Tim Mooney
developing Gpib devSupport mauro
<1998>
RE: EPICS r3.13 field DESC length Jeff Hill
<1998>
