1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: trying to add 64M offboard memory to system pool
To: [email protected], [email protected]
Date: Tue, 23 Dec 1997 16:49:57 -1000
Sorry, just to clarify things,  the nfs error is just on of a couple of
errors I encounter.  Others would be bus error or rpc errors.
Without the call to memAddToPool the startup script works fine.
Kevin
> From [email protected] Tue Dec 23 16:24:29 1997
> Date: Tue, 23 Dec 1997 16:08:26 -1000
> From: [email protected] (Kevin Tsubota)
> Subject: trying to add 64M offboard memory to system pool
> Content-Type: X-sun-attachment
> Content-Length: 79460
> Configuration:
> frc40 16M cpu
> micro memory MM6260AD 64M memory card
> vxWorks 5.1.1 and vxWorks 5.3.1
> We have a frc40 16M CPU card running vxWorks and needed more memory so
> we purchased a 64M memory card from micro memory.  I've been able
> to read and write practically all 64M on the card, both as longs and
> doubles.  However when I attempt to do a vxWorks ld command from the
> target shell I always get an error.  I've had this error in vxWorks
> 5.1.1 and I've just upgraded to vxWorks 5.3.1 with the same results.
> I've tried it in the windsh and it loads but I get other errors.
> I would prefer to run it from the target shell as the startup script.
> I've been fighting this for some time now with help from vxWorks but
> I'm still at square one.
> Has anyone else done anything similiar?
> I've attached the output from vxWorks 5.3.1 target shell as well as my configAll.h and sysLib.c files.
> I'm using bfill to set the parity bit and memAddToPool and want to freely use
> the offboard memory without specifically addressing it.
> Thank You.
> Kevin Tsubota
> W.M. Keck Observatory
> (808)885-778
> [email protected]
Prev: trying to add 64M offboard memory to system pool Kevin Tsubota
Next: printing UniDraw files Russell J. Page, Sr.
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
