1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: CA Repeater Problem on OpenVMS Systems using MultiNet
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 18 Nov 1997 13:28:05 -0700
Stephanie,
I agree with your assessment of what happens to the VMS CA repeater in
the presence of the MULTINET bug you described. I also agree that the
CA repeater will be more robust when this (or other) IP kernel implementation(s)
fail(s)  in a similar way if the changes you described are installed. I installed
your changes.
I should also add that I for one am sick and tired of strange CA
repeater problems showing up resulting from differences in IP kernel implementations.
Since almost all IP kernel implementations now include the IP multicast
enhancements it should be possible to perform CA connection management
functions without using the CA repeater on all of the commonly used OS.
I am looking into this.
Jeff
______________________________________________________
Jeffrey O. Hill                      Internet     [email protected]
LANL MS H820                    Voice         505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Prev: CA Repeater Problem on OpenVMS Systems using MultiNet saa
Next: devVXStats.c Marty Kraimer
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
