1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ascii to dbd
To: [email protected]
Cc: [email protected]
Date: Fri, 14 Nov 1997 07:58:07 -0600
> Hi Folk,
> I'm looking for a tool to convert .ascii files into
> dbd format. Could you help ?
> Reegards,
> Gabor Csuka
> DESY , Germany
I grabbed this paragraph from the "EPICS Release Notes R3.13.0Beta4"
on the ANL Documentation site. I think it will do what you want.
default.dctsdr conversion tools
NOTES
       In the following default.dctsdr is optional. If not given the tool just
looks for the file "default.dctsdr" in the current directory.
       All output files are placed in the directory from which the tool is
executed.
The following tools are provided:
       sdr2gblmenu [default.dctsdr]
       All global menus are written as separate files.
       sdr2recordtype record_type record_type.h [default.dctsdr]
       A record type definition file is generated.
       sdr2device [default.dctsdr]
       All device definitions are placed in a file called device.dbd
       sdr2driver [default.dctsdr]
       All driver definitions are placed in a file called driver.dbd
For all utilities the required database definition files are generated from a
dctsdr file from a previous epics release. A dctsdr file can be specified or
else the utilities can
be run in a directory which contains default.dctsdr (or a soft link with that
name). sdr2recordtype also requires the header file generated by a previous
epics release.
Prev: ascii to dbd Gabor Csuka
Next: Re: ascii to dbd Ralph Lange
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ascii to dbd Ralph Lange
Next: asking hxm
