1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: PLC Ethernet Modules
To: [email protected], [email protected]
Date: Thu, 9 Oct 1997 13:43:07 -0500 (CDT)
There are several Collaborative Access Teams at the
APS that are using Koyo programmable logic controllers
marketed through PLC Direct.  Their new catalog has two
new offerings that may be of interest to the EPICS and
beamline communities.  PLC Direct is now shipping an Ethernet
Base Controller for their 205 series of PLC's.  This controller
takes the place of the CPU and allows a computer to control devices in the
backplane using IP or IPX via 10-Base-T networking cable.  You
can only access binary I/O and analog I/O with the EBC.
However, one can have remote binary and analog inputs and outputs
in a stand alone DIN mountable controller.  PLC Direct's prices
are extremely competitive.  Just as an example, lets say you needed
a few binary/analog/input/output/relay modules, one configuration might
be:
9 Slot Base                 $161.00
EBC Controller              $249.00
16 Point Output Module      $ 71.00
16 Point Input  Module      $ 69.00
8  Point Relay  Module      $ 80.00
8 Channel Analog Input      $194.00
   Module (12 bit)
2 Channel Analog Output     $139.00
   Module (12 bit)
Filler modules for
remaining 3 ports @         $ 15.00
  $5 apiece
                            $981.00
$ are US dollars
By the end of the year, they claim that they will be shipping
an ENET module which is an ethernet communication module that can
be used to talk to a PLC system.   We at DND will be revamping the
communications on the beamline to take advantage of these new products.
The PLC direct web site claims that an ENET module will also be available
for the 405 PLC series as well.
- John
John Quintana                              Phone:630-252-0223
Northwestern University                    FAX: 630-252-0226
DND-CAT                                    email: [email protected]
APS/ANL Building 432/A003
9700 South Cass Avenue
Argonne, IL 60439
Prev: pvload / pvsave William Lupton
Next: VMIC VME-3801 question Arun S, Bommannavar
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
