1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Enhanced vxWorks Variable Support
To: [email protected]
Cc: [email protected]
Date: Thu, 25 Sep 1997 08:39:56 -1000
Dear all,
Marty wrote:
> Question? Is everyone agreed that this should completely replace
> the existing dev*Symb* support that is in base?
I should clarify that the existing VxWorks device support uses input
and output link types of CONSTANT and ignores the PARM field (the name
of the VxWorks variable is derived solely from the record name). The
new support uses a link type of INST_IO and parses the PARM field to
determine the VxWorks variable name. The new support also supports a
link type of CONSTANT and should be completely backwards-compatible with
the existing support.
Also:
> Can you make a tar file and make it available via anonymous ftp?
> Include the README file. I will convert devSup.ascii to the 3.13
> format.
OK. Will do once our FTP access is back online...
William
Prev: RE: Enhanced vxWorks Variable Support Jeff Hill
Next: VMIC 2120 Support Graham Waters
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Archiving & save/restore update Bob Dalesio
