Hello all,
> I want to read out a VME memory board using a waveform record.
> The VME memory board is located at 0x006c0000. I want to readout 100
> unsigned long elements beginning at the memory board's base location.
> In a response from Rozelle Wright, I found out that this problem
> has been solved by Andrew Johnson. Below is a message from Andrew Johnson
> regarding the enhanced vxWorks variable support package. Does there exist
> a version for R3.13 and has it been tested with R3.13?
Some advantages of taking the time to write custom device support for
your waveform device...
o vxMemProbe is used during initialization (no bus error when card not present)
o sysBusToLocalAddr() or devLib style address mapping (database is CPU model
independent)
o database addresses device by card number (easy to add additional cards and
rearrange the address map without changing the database)
o synchronize the database with updates to the waveform (avoid fetching
part of the waveform from one data take and part from another)
o diagnostics for this card show up in dbior() (IO reports)
o database can enter alarm state when the card is sick
Jeff
______________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Archiving & save/restore update Bob Dalesio
Re: Enhanced vxWorks Variable Support William Lupton
<1997>
Re: Enhanced vxWorks Variable Support Marty Kraimer
<1997>
