1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: frame grabbers
To: [email protected]
Date: Tue, 9 Sep 1997 07:01:07 -1000
[email protected] writes:
 > Hello All,
 > 	We have an application where we need to multiplex six
 > camera images of laser spots and syncrotron light images and process these
 > images to find the centroid and width of each image.  An update rate of
 > one image per second is would be OK.  If the hardware is cheap we could
 > purchase 6 frame grabbers and do away with the multiplexing.  Is anyone
 > doing this or something similar in EPICS?  Any help is appreciated.
 > Thanks,
 > Coles
Coles -
	We are using the Data Translation DT-1451 to process video
frames for use as telescope guider. Frame grabber speed is 1/30
second, we integrate every 10 frames, and find the centroid of a hot
spot (actually the image of the star used for guiding) within a small
region of interest.
I think the DT-1451's are fairly cheap - but DT doesn't officially
list them in their catalog. We also had to take their SunOS driver
software and port it to a Sparc 5 IOC. EPICS support is mostly in the
form of MOSUB records.
Peregrine
frame grabbers SIBLEY
Prev: frame grabbers SIBLEY
Next: Military Service. Help needed !!! Eric Boucher
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
