1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: tcl/tk , tcl-dp and blt which and where?
To: [email protected]
Cc: [email protected]
Date: Wed, 20 Aug 97 18:59:51 CDT
Rozelle:
Who is maintaining et_wish?
[et_wish is the executable built in <extensions>/src/tcl_et]
Here's one recipe for a working et_wish extension.
I have built a version of et_wish just this week with some
components of Tcl/Tk/BLT.  By the way, it was built on
a Sun Solaris 2.5.1 platform with EPICS R3.12.2
and a Linux v2.0.0. platform with EPICS R3.13.0beta4
with the same source (or so I think).
Since UNICAT has not been using Tcl-DP, I have undef'ed it
in my caAppInit.c module and edited the Makefile.  If you
want to use Tcl-DP, you can uncomment where appropriate.
I made one other change to the source I got last year
from Claude Saunders at APS.  See below for the note.
How do you know if you've got Claude's revised tcl_et?
In the revised version, there are only about 5 source
code modules: caAppInit.c, et.h, etca.c, ethash.c, ettcl.c
I believe the earlier version had more source code modules.
Anyway, Claude's version works, if you accept the one caveat below.
For a limited time, you can have at a tar.gz file of
my tcl_et source tree by going to:
 UNICAT Software Distrib.:  http://unicat.aps.anl.gov/controls/index.html
   tcl v7.6      http://www.tcltk.com
   tk  v4.2      http://www.tcltk.com
   BLT v2.3      ftp://ftp.neosoft.com/pub/tcl/sorted/devel
     (as an aside, I've also built expect 5.22 with the
      same Tcl/Tk but did not try to combine BLT as well)
   expect v5.22  http://expect.nist.gov
I have not been successful in building with Tcl/Tk/BLT v8.
VERY SPECIAL NOTE:
  BLT had a significant upgrade between v1.8 and v2.1 that changed
  the interface used by et_wish to efficiently handle EPICS array data.
  I have commented out that code (in etca.c) for the time being.
  Looks like there is a very simple way to modify that using BLT's
  vector data structure (new with v2.1).  However, round tuits
  are scarce these days.
  This _ONLY_ affects the linking of EPICS arrays
  (anything that uses vdis and the Blt_GraphElem call which
  went away with the BLT v2.1 upgrade.)
Pete Jemian
UNICAT
-----------------------------% clip here %-----------------------------
Rozelle Wright wrote this today:
> Can some expert in building tcl/tk for epics please help me.
> I am trying to build the epics extensions applications that need tcl/tk
> I am a beginner at using tcl/tk, so
> I was pleased to see links in the distribution page to
> the places to get the source for these.
> However,
> 1. Tcl-DP gives me the error
> "http.cs.cornell.edu
> The server does not have a DNS entry"
> ,so I can't get the source for it. Does anyone know
> where it is?  and which epics applications need it?
Last time I found Tcl-DP, it was April 1996 at:
http://www.cs.cornell.edu/Info/Projects/zeno/Project/Tcl-DP.html
That link may have been toasted since, though.
If you can't find it on the net, I can tar up my source distribution
of v3.4b2 and post it for you.
> 2.  Am I right in assuming that I need the patches as well as the
> original source for tcl and tk and blt.  These are
> the files I currently have.  Are they the right ones?
> blt-1.8.tar.gz           tcl7.4p1.patch.gz        tk4.0p2.patch.gz
> blt-1.8to1.9.0.patch.gz  tcl7.4p2.patch.gz        tk4.0p3.patch.gz
> tcl7.4/                  tcl7.4p3.patch.gz
> tcl7.4.tar               tk4.0p1.patch.gz
> I am assuming that when it says tcl7.4 tk4.0 nothing later will do
> and I'm not sure about blt.
This sounds like a workable combination.
Don't use BLT 1.8 (or 1.0 or 2.0) for Tcl 7.5.
There's an older tcl_et that works with:
Tcl 7.4 and Tk 4.0 are a pair.  BLT 1.8 works, as does Tcl-DP 3.4b2
Claude's changed tcl_et works with:
Tcl 7.5 and Tk 4.1 are a pair.  BLT 2.1 works, maybe BLT 2.3, Tcl-DP?
Tcl 7.6 and Tk 4.2 are a pair.  BLT 2.3 works, Tcl-DP?
Tcl 8.0, Tk 8.0, and BLT 8 are a set but are not yet in final release.
Also, BLT 8 is unofficial since others are attempting to pick
up the support for the overburdened developer (George Howlett).
Unless you need the EPICS array support _right now_, I thoroughly
recommend the Tcl/Tk/BLT 7.6/4.2/2.3 combination.
Prev: Re: tcl/tk , tcl-dp and blt which and where? Steve Lewis
Next: Re: tcl/tk , tcl-dp and blt which and where? Pete Jemian
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
