1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: NFS vxWorks UMASK
To: [email protected]
Date: Mon, 28 Jul 1997 08:56:55 -0500
Ralph Lange wrote:
> Hi Marty,
> > At the end of our vwXorks startup files we execute the command:
> > dbl > some_file
> > If the file is written via ftp it has the protections:
> > -rw-r--r--
> > I it is written via NFS it is
> > -rw-r-----
> > Does anyone know how we can make the NFS create the file with:
> > -rw-r--r--
> I proposed this question to my favourite WRS support engineer and the
> official answer is:
> [ If you supply a "mode" in the open() call, it will be the file mode -
> [ default permissions otherwise.
> [ nfsLib.c :
> [     createArgs.where.name = fileName;
> [     pSattr = &createArgs.attributes;
> [     if (mode == 0)
> [         /* create a file with default permissions */
> [         pSattr->mode = NFS_FSTAT_REG | DEFAULT_FILE_PERM;
> [     else
> [         pSattr->mode = mode;
> Ralph
In our vxWorks distribution I did a grep for DEFAULT_FILE_PERM
and sure enough I found
h/ioLib.h:#define DEFAULT_FILE_PERM     0000640
Changing the value to 644 should solve the problem
By the way I did change dbl so it accepts an optional 2nd argument
which is a file name. dbl then executes
fd = open(filename, O_CREAT | O_WRONLY | O_TRUNC, 0644 );
This solved the problem for dbl.
Ralph's solution solves the problem for all commands of the form
xxx > "file name"
Marty
Re: NFS vxWorks UMASK Ralph Lange
Prev: MAC4 with EPICS? Thomas Hahn
Next: Re: posting archive monitors on dbPut() Marty Kraimer
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: NFS vxWorks UMASK Ralph Lange
Next: Re: NFS vxWorks UMASK Ralph Lange
