1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Building EPICS on HP_UX 10.2
To: [email protected] (Dave Reid), [email protected] (EPICS Tech-Talk)
Date: Mon, 21 Jul 1997 12:30:39 +0200 (METDST)
Hi Dave!
> 	If I have built EPICS for HPUX9.05 and have now
> 	migrated to HPUX10.2 will I need to rebuild EPICS?
No.
The cross-compiler for vxWorks is still the same binary - so there's no
cross compilation necessary.
The HPUX binaries are upward compatible - 9.0x binaries will run on all
10.x machines. Any 10.x binary will run on the same or higher version of
HPUX. We still have some 9.0x binaries in our global epics/bin/hp700
directory - no problems.
There is a slight difference: Under 9.0x the /bin/sh is *not* POSIX
conformant, under 10.x it is. (If you encounter problems with shell scripts
under 9.0x, use /bin/posix/sh instead.) As EPICS scripting has been moved
to perl, this should not bother you.
Ralph
Building EPICS on HP_UX 10.2 Dave Reid
Prev: bug or feature?? Rolf Keitel
Next: Re: database check in R3.13.0 Ralph Lange
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Building EPICS on HP_UX 10.2 Dave Reid
Next: Re: InitHooks Marty Kraimer
