1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: EPICS fd registration problem
To: "'Firmin Oliveira'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 17 Jul 1997 15:40:23 -0600
Firmin,
You need to call "ca_task_initialize()" prior to calling
"ca_add_fd_registration()". The attached modification of
your source works correctly. Most of the CA functions
will call "ca_task_initialize()" for you if you forget to
take care of it, but this one does not. I will make this
one consistent with the others in EPICS 3.13.
Jeff
#include <stdio.h>
#include "cadef.h"
void FdRegHandler(void *, int, int);
int main()
	int CaStatus;
	int vparm;
	CaStatus = ca_task_initialize();
	SEVCHK(CaStatus,"ca init failed");
	CaStatus = ca_add_fd_registration(FdRegHandler,&vparm);
	return 0;
void FdRegHandler(void *vparm, int fd, int cond)
   printf("In FdRegHandler\n");
On Thursday, July 17, 1997 2:19 PM, Firmin Oliveira
[SMTP:[email protected]] wrote:
> Hello,
> I have little to no EPICS channel access experience
> I have been trying to run my program with ca_add_fd_registration. It
> compiles/links okay, but when run it produces a segmentation fault upon
> entry into ca_add_fd_registration.  I have tried every combination of
> arguments I know into the routine but it continually gets a segmentation
> fault.  When the ca_add_fd_registration statement is commented out, the rest
> of the
> channel access routines work just fine (ca_task_initialize,
> ca_search_and_connect, ca_get, SEVCHK, ca_add_event.)  To be more specific
> about the problem:
>    include "cadef.h"
>    main()
>    int CaStatus;
>    my_struct vparm;
>    (Note: Segmentation fault occurs in above statement)
>    printf("In FdRegHandler\n");      (Note: this does not get printed)
> Any help you can give would be appreciated.
> Aloha,
> Firmin Oliveira
Prev: base release 3.13.0beta11 Marty Kraimer
Next: European EPICS Meeting J.F. Gournay
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: EPICS fd registration problem Firmin Oliveira
Next: base release 3.13.0beta11 Marty Kraimer
